Hello,
my car is having DPF problems since this January and my local mechanic has not been able to solve it yet.
At first the DPF light turned on at times, more and more frequently. Then with also the check engine light. The code being P2003.
At first they only suggested I drive it for longer routes.
Then they forced a regeneration.
Then they (supposedly) took out the DPF and sent the part to be cleaned. I say supposedly because this didn't change anything and the sooth mass I read with a bluetooth ODBII+Car Scanner was unchanged from before and after.
Now the car keep having the check engine on, and the DPF light turn on every time I do more than 15 km or so.
I've started adding additives for better DPF regenerations just in the hope of doing something.
I'm also looking to use some cleaning tool myself since I lost trust in the mechanic.
Any suggestion?
Then I need some help for the cleaning part.
I've looked up my VIN in ilcats.ru and partsouq.com and looking at the exhaust system (
here on partsouq) the DPF I suppose is the block 28900.
Right?
And if I correctly identified the DPF, I suppose it is accessible from the hood, just behind the motor . And to apply a product like this
DPF cleaner I suppose I just need to unplug the sensor on top.
I tried to search the forum (and internet in general) before bothering someone but I couldn't find the confirmation of my suspicions.
Any help is greatly appreciated.
Thanks.
