gd 2014 diesel - intermittent wipers issue
ro0sau · 2 · 7701
Offline ro0sau
hello
just wondering if anybody has ever had a problem with front window wipers on intermittent setting.
mine will stop half way thru a cycle and the blade stops right in front of my face, so annoying.
doesn't matter which intermittent speed they are set to...and the wipers work normally on other wipe settings.
if i just let them do their own thing, they will do like 2 cycles stopping mid way and then the next cycle will work normally and then back to stopping once again. the blades also will not seat in normal  idle position unless the motor does a normal swipe. the same issue can occur if I try moving the stalk up to do a single clearing cycle   :Dunno:
  • 2015 gd i30 trophy auto diesel
Offline ro0sau
replaced faulty micro changeover relay :kissmyass:
