Hi all, and thank you for accepting me into the group. As I'm new i'll apologise in advance if this topic has been covered 1000 times before, but I would like some input from other users before spending a lot of money on unnecessary repairs!
Basically it's the same problem we've all seen reported numerous times before, notchy gear changes and grinding going into particular gears. In my case it's 4th gear, and I was told the syncro would need replacing.
I'm just wondering if it would be worth trying to replace the gearbox oil and trying to make adjustments to linkages before pulling the trigger on a syncro replacement? I thought I read somewhere that this worked for someone before.
The clutch was replaced 10 months ago so I don't expect its that.
Any feedback on this is much appreciated.
David
2014 i30 1.4 CRDI 6 Speed
