I30 CRDI GD Auxiliary Belt issues
Offline Mumfy73
      Two Rocks, Perth WA
So after many faultless kms on my i30 i now have a issue
My belt broke and was replaced with a hyundai genuine one but i had a engine noise, before replacing the the belt i ran the engine no noise, belt on and noise, the tensioner was also noted that it was bouncing about, So that was replaced all idlers checked no play
Its like the belt is loading up and unloading ............the noise at tick over is still there but as soon as you accelerate it disappears
No noise when the belt is removed
Im a little stuck
Just a little about me I run Landrovers so have rebuilt engines, gearboxes diffs etc
  • I30 CRDI GD 2013 Wagon
PGN I30
Were all the pulleys checked or just the idlers?
Offline Mumfy73
      Two Rocks, Perth WA
Yes all checked no play detected in anything
PGN I30
What length is the belt, is it the correct one? I was thinking maybe it is too long, can't think of any other reason why it would make noise.
Offline TerryT
      Sydney, NSW
That could be the most unintended damming indictment against Landrovers I have ever read. :rofl:.   :lol:   :snigger:
(I owned a SWB II for a little while.  Great vehicle, but no creature comforts.  We did the Holden conversion thing (dropped in a red engine, bored and balanced, lightened flywheel etc).   Cannot remember why now. :)  It was an absolute screamer on the streets against unsuspecting traffic light draggers... but it lost that lovely first gear tick-tick torque up/down hills in the bush).
PGN I30
Crankshaft pulley appears to be vibrating causing the issue.
Offline Mumfy73
      Two Rocks, Perth WA
No that’s not an issue with it pulsing it lead me to the alternator pulley which when replaced solved the issue
PGN I30
I thought you said the idlers and pulleys had been checked, what was wrong with alternator pulley?
