Clutch issue, Low bite!
Ct7331 · 11 · 3219
Offline Ct7331
Hi all!
Having a few issues with a 15 (GD?) 1.4 Petrol.
The bite point is on the floor for the clutch, very hard to select gears.
No visible leaks from slave, master looks ok.
Tiny bit of play in master rod to pedal. Do the forks at the end of the slave bend?
Been doing quite a bit of research and somewhere it said the splines on the pressure plate bend.
So im thinking it must be a bent fork or failed pressure plate? Cant see any leaks and the petrols dont have a clutch dampner
  • 15 GD 1.4 Petrol
Have you been able to do the clutch plates test to establish whether the clutch itself may require renewing.
i.e.
Put handbrake fully on.
Start engine.
Put gear lever into 2nd.
Let clutch pedal up slowly to bite point but do not release handbrake.
If clutch plates ok car should be trying to move forward and bonnet raising up.
If not then revs will rise with no intention of trying to move forward.
Offline Ct7331
Yes, acts as normal. Tries to pull away. Also to add, there isnt any clutch slip when driving.
Im going to try taking up the slack in the master cylinder rod first i think.
  • 15 GD 1.4 Petrol
Offline asathorny
  • Wonky Donkey
  • Curmudgeon
I recall way back in 2010 when we were all pretty new to Hyundai.  There was much discussion about the clutch bite point, being too low.  As we all got used to our new cars things seemed to settle down.  I know this isn't much use for you.
Good luck with your problem
Offline Ct7331
Thank you, but its too low to the point it will barely let you engage a gear, its milimetres off the floor bite wise.
  • 15 GD 1.4 Petrol
Offline asathorny
  • Wonky Donkey
  • Curmudgeon
Yeah, that does sound a bit too low, good luck  :goodjob:
Offline BrendanP
How many miles has it done? I have posted a video on Youtube showing the clutch out of my old FD diesel
:link: Hyundai i30 clutch after 250K miles - YouTube
The slave cylinder was also leaking, though it wasn't obvious unless you pulled back the rubber boot.
Offline Ct7331
Little update
No leak on slave, fluid bled through fine
Master rod wasnt the cause.
So it must be either the friction plate, pressure plate or the fork
  • 15 GD 1.4 Petrol
Offline asathorny
  • Wonky Donkey
  • Curmudgeon
has it got one of the really reliable hyundai clutch pressure regulators? worn pushrod at the master end?
Offline Ct7331
That was all ok
I replaced the friction plate, pressure plate and bearing. That solved the issue. I believe the fins in the centre of the pressure plate had bent slightly.
  • 15 GD 1.4 Petrol
