Window stuck down
Offline Kreekeraux
    • nz New Zealand
      Nz
Hey all, I've tried searching but not sure mine is the same issue. Diagnosing this for my wife as we're remote so not a candidate for mobile mechanic. There is a car being wrecked not too far though..
Wife wound her window down and said the window broke inside the door as she heard it break.  Took the door skin off but the window seems intact (or at least the top part is). Motor is actuating (or moving from the sound sof it) at least a little but window isn't moving at all. I can't remove the window regulator to check as it's stuck down. Is there a trick or something someone can suggest please? Am stumped..
Cheers,
Trav
  • 2007 i30
Online The Gonz
Certainly sounds stumpworthy. Are you sure the window can't be raised by hand with the door card off?
