Problem with Traction control light
Raj · 3 · 2084
Offline Raj
    • Leicestershire
Hello. Can anyone help me about my Hyundai i30 diesel 1.6, 2012.
Traction control light shows when car drive above 45 mile per hour and it doesn't show on dashboard that which next gear is required.
If i use it on less than 45 mile per hour speed then it don't show any light.
All censors and barring are good and working.
Please  help me to solve this problem as soon as possible.
Thank You.
  • Hyundai i30 2012 1.6 diesel
Offline gagsi011
    • cs Serbia
The problem is with one of the two clutch sensors located on the clutch pedal. The one that is deeper and is located above the pedal usually gets stuck.
Послато са SM-G975F помоћу Тапатока
  • Hyundai i30 gd crdi
Offline Aye30
It will also turn off esp if both brake light circuits are not completed. 2012 could be 4 pin brake switch model.  Check all rear brake lights.
