Window weather strips
CRC · 2 · 1483
Offline CRC
      NSW
Looking for recommendations for a supplier (to Australia) of a set of Window Weather Strips for a 2009 1.6FD Diesel
Alternatively, has anyone simply replaced the rubber strip, and if so can you please provide details. Rubber specs and supplier please.
« Last Edit: April 30, 2024, 04:51:43 by CRC »
  • i30 FD 2009
Offline raypinkerton
      Geebung, Brisbane
  • 2008 SLX 1.6 CRDi Auto
I was gathering part numbers for weather seals for the doors on my FD from a Korean online supply company. As far as I'm aware these as USD prices. I think I have understood the parts breakdown correctly.
Front Door (on body)
821402L000   WEATHERSTRIP ASSY - FRONT DOOR SIDE RH   82140B   20.02.2008 - 08.05.2012
821302L000   WEATHERSTRIP ASSY - FRONT DOOR SIDE LH   82130C   20.02.2008 - 08.05.2012
Rear Door (on body)
831102H001   WEATHERSTRIP - REAR DOOR BODY SIDE LH      83110B   20.02.2008 - 08.05.2012      $38.02
831202H001   WEATHERSTRIP - REAR DOOR BODY SIDE RH   83120B   20.02.2008 - 08.05.2012      $38.02
WEATHERSTRIP BELT MOULDING OUTSIDE
822202L000   WEATHERSTRIP ASSY - FRONT DOOR BELT OUTSIDE RH   82220   20.02.2008 - 08.05.2012      $18.63
822102L000   WEATHERSTRIP - FRONT DOOR BELT OUTSIDE LH   82210A   20.02.2008 - 08.05.2012      $18.63
822192H000   CLIP - DOOR BELT OUTSIDE WEATHERSTRIP MOUNTING   82219   20.02.2008 - 08.05.2012 10 pcs   $ 0.53
832102L000   WEATHERSTRIP ASSY - REAR DOOR BELT OUTSIDE LH    83210   20.02.2008 - 08.05.2012      $19.36
832202L000   WEATHERSTRIP ASSY - REAR DOOR BELT OUTSIDE RH   83220   20.02.2008 - 08.05.2012      $19.36
INSIDE
822312L000   WEATHERSTRIP - FRONT DOOR BELT INSIDE LH   82231   20.02.2008 - 01.09.2008      $14.21
822412L000   WEATHERSTRIP - FRONT DOOR BELT INSIDE RH   82241   20.02.2008 - 01.09.2008      $14.21
832312L000   WEATHERSTRIP - REAR DOOR BELT INSIDE LH      83231   20.02.2008 - 08.05.2012      $13.67
832412L000   WEATHERSTRIP - REAR DOOR BELT INSIDE RH      83241   20.02.2008 - 08.05.2012      $13.67
Maybe these part numbers will help in your search.
Ray
