ESP light on dash
Offline fafer88
      West Yorkshire
Hello,
I had problem with my 2012 Hyundai i30 GD, every time I get into 60mph ESP light turns on and stays on till I turn engine off and then after I start it again it's stays off till I get into 60mph.
I read fault codes and I have 1 in ECU P0704 - Clutch switch input malfunction - permanent and 1 in ABS C1520 - Clutch switch - Intermittent. I bought a genuine clutch switch from Hyundai dealer but it didn't cure it. Does anyone knows what is the problem? Do You know if there is TSB for that fault?
cheers
  • 2012 GD 5 Door Hatch, Petrol 1.4lt, Manual, White
Offline Aye30
Hi, just looking back at some older posts, reveals that there might be 2 clutch switches. does your I30 have two?
Offline fafer88
      West Yorkshire
I've got just one switch p/n 93840 2E000
PGN I30
There are 2 switches, one at the top and one at the bottom if I remember correctly.
