Windscreen not clearing
Offline GCC2024
      Hertfordshire
Hello everyone, I have a new issue with my 2009 i30 crdi. Last week I was driving on a motorway on a wet day and needed to demist the windscreen and windows so I turned on the blower as normal but instead of clearing the screen it misted up even more. Thankfully I had a towel in the car so was able to wipe the screen instead but I was concentrating so much on keeping the screen clear that I didn’t take note if the blower was warm or not. There was also a strange smell, unfamiliar, not sure if it was anti freeze smell or something else quite sickly. The inside of the screen was getting “oily” but that could have been from the dirty towel I was using. At home I checked the water level in the reservoir and it was empty. I topped it up but a week later it has gone down again and today there was smoke or mist coming out of the blower vents- never seen that before. And the screen still won’t clear, either with AC or not. Do any of you wonderful experts have any ideas please ? Thank you very much
  • I30 diesel estate
Offline Greyhound
So in summary you have misting inside windscreen and loss of coolant. That sounds like a coolant leak, maybe at the heater matrix.
Normally any misting can be cleared using air-con, but not for you it seems.
Is there any sign of wetness on passenger side floor or glovebox area?
Any coolant on ground under car?
This may be worth a read: :link: Heater Matrix blocked and leaking
  • i30 PD 2020 1.0 T-GDi
Offline GCC2024
      Hertfordshire
Thank you for your reply. Yes it seems the heat exchanger is leaking. And like the other post, the garage quoted more than the car’s value to replace it ! I am not qualified to even dabble with mechanics so a £10 bottle of radweld is going in, if it’s no good then it’s time for an upgrade ! Thanks again
  • I30 diesel estate
