Accident Repair / Offside Headlight assembly replacement
Dmehta · 2 · 1087
Offline Dmehta
      Leicesterp
Hi, Unfortunately had my i30 in an accident got wing and headlight damaged.
Wing is going to be replaced but for headlight assembly only the casing glass had broken all internals and mounts are intact with headlight running. Is there a way I can only replace the outer casing / glass or do I need to replace whole assembly ?
Also genuine headlight is way expensive and with part number can’t find same but had found 20-14319-05-2 TYC Headlight for Hyundai on Ebay. Will that be correct for my UK 2012 reg I30 GD1.6 diesel ???
Also anyone from Leicester UK can recommend good bodyshop or garage ???
« Last Edit: December 16, 2024, 22:27:39 by Dmehta »
  • 2012 GD UK I30 5 door hatch 1.6 CRDI
Offline BrendanP
Even if you could replace the front lens, and I think it's glued on, where could you get one from other than a complete headlamp? In which case you'd swap out the complete unit. Have you gone on www.partsouq.com and double-checked the part number after searching with your VIN number? The headlamp units are very expensive, and I'm sure the car breakers know that.
