TSBs (Technical Service Bulletins)
babis_xo · 32 · 38277
Offline babis_xo
  • 6* dummy
    • gr Greece
  • ...em ot keerG lla s'ti
Administrator Comment NOT ALL LINKS IN THIS TOPIC MAY RESOLVE, HOWEVER THEY ARE RETAINED FOR THEIR REFERENCE NUMBERS
Technical Service Bulletins related links to "hyundaiserviceman.com" & "ceedonline.info" (public websites)
Date Publ.  TSB No. & Description
UPDATED 07/09/2011
07.08.2010  HFE10-21-P060-HDFD (*)
            HD/FD FRONT STRUT NOISE REPAIR
17.06.2010  HT2007052911 (*)
            SERVICE INFORMATION FOR SUSPENSION SYSTEM
17.06.2010  HGR09-12-P190-FD (RUS)
            MAINTENANCE INTERVALS & LUBRICANTS RECOMMENDED FOR 2010 FDe CARS
17.06.2010  HT2007051602 (*)
            HEAD LAMP AND FOG LAMP AIMING INSTRUCTIONS FOR 2008 i30(FD)
07.06.2010  HFE08-61-P020-FDHD
            TSB. MDPS WORM SHAFT FLEXIBLE COUPLING REPLACEMENT
26.05.2010  SDTB 2010-051
            STANDARD iPOD CONNECTOR FOR HYUNDAI
25.05.2010  HFE10-14-E300-HDFD
            ECM UPDATE – HD/FDE 1.6 IDLE RPM LOGIC
20.05.2010  HFE09-21-P261-HDFD
            (REVISED: see HFE10-21-P060-HDFD) FRONT STRUT NOISE REPAIR (FROM SHOCK ABSORBER'S BUMBER-STOP)
20.05.2010  HGE10-41-P020-al
            PRECAUTIONS BEFORE ADDING OR CHANGING BRAKE FLUID
17.05.2010  HCE10-91-P160-FD
            i30 (FDe) VEHICLE IDENTIFICATION LABEL REPLACEMENT
16.05.2010  HT201005126
            PROCEDURE TO INSPECT BRAKE DISCS
07.05.2010  HFE10-92-C140-FD
            i30 (FDe) REMOTE KEYLESS ENTRY DOOR LOCKING INOPERATIVE
27.04.2010  HGE09-11-P050-FD
            INTRODUCTION TO STOP & GO SYSTEM
07.04.2010  HFE09-53-P020-MCHDFD
            CREAKING NOISE AT IDLE
07.04.2010  HGE09-12-P060- MCPAHDFDTBFC
            CHANGES IN U-1.1L/1.5L/1.6L DIESEL ENGINE PARTS
07.04.2010  HGE09-12-P121-HDFDPB
            (REVISED) CHANGES IN GAMMA 1.4L/1.6L ENGINE PARTS
07.04.2010  HGE09-12-P131-HDFDPB
            (REVISED) CHANGES IN GAMMA 1.4L/1.6L ENGINE CYLINDER HEADS & PISTONS
07.04.2010  HGE09-12-P170-HDFD
            HD/FD U-1.6L DIESEL ENGINE OIL COOLER ASSEMBLY CHANGE
07.04.2010  HGE09-12-P210-HDFDPB
            HOW TO MEASURE ? 1.4L/1.6L ENGINE DRIVE BELT TENSION
07.04.2010  HGE09-12-P240-al
            CAUTIONS DURING ENGINE OIL CHANGE AND OIL PAN REMOVAL
07.04.2010  HGE09-12-P460-HDFDPB
            CHANGES IN GAMMA 1.4L/1.6L WATER PUMP & WATER PUMP PULLEY
07.04.2010  HGE09-14-P040- MCPAHDTBFDFC
            TOOLS FOR REMOVAL OF U-1.1L/1.5L/1.6L DIESEL ENGINE HIGH PRESSURE FUEL PUMPS
07.04.2010  HGE09-14-P180-FDHD
            CHANGE OF DELIVERY PIPE OF HD/FD BETA ENGINE
07.04.2010  HGE09-14-P221- PAPBTBMCHDFD GKNFJMFOTQ
            (REVISED) ISCA (IDLE SPEED CONTROL ACTUATOR) CLEANING INSTRUCTIONS
07.04.2010  HGE09-61-P010-HDFD
            ABSOLUTE STEERING POSITION (APS) CALIBRATION ON ELECTRIC POWER STEERING (EPS)
07.04.2010  HGE09-61-P030- FDHDMCPAPBTB
            EPS OVERHEAT PROTECTION FUNCTION – C1603
07.04.2010  HGE09-81-P050-MCHDFD
            MC/HD/FD IMPACT SENSOR & AIRBAG CONTROL UNIT CHANGE
07.04.2010  HGE09-92-P430-PARV
            LOCATIONS OF POWER CONNECTORS (MEMORY FUSE OR SHUNT CONNECTOR)
26.03.2010  HFE08-52-P170-HDFD
            PAD ADDITION TO A/T CONTROL CABLE MASS DAMPER
18.03.2010  HGE08-81-P070-FD-NO
            CHANGE OF PASSENGER AIRBAG ON-OFF SWITCH
05.11.2009  HGE09-10-P012-al
            (REVISED) VIN DECODER FOR 2010 MODEL YEAR CARS
      2010  ELECTRICAL SCHEMES i30 (FD) 2010 1.6 DOHC (*)
      2010  HARNESS i30 (FD) 2010 1.6 DOHC
(*) file not available
  • 1.4 HB Classic '09 White
:D
Splendid information - great post Babis :)
Shame about that "file unavailable" link....
Offline babis_xo
  • 6* dummy
    • gr Greece
Thanks Steve :)
A couple of weeks ago there were more files unavailable. Maybe this is a random issue.
Yep.. good work babis...thanks... :mrgreen:
Edit: I have an appropriate witticism for you...
How about "it's all Greek to me..."
Thankfully the site is unrelated to i30oc so it wont be us getting the desist notice this time  :wink:
Absolutely.
Offline babis_xo
  • 6* dummy
    • gr Greece
Done :lol:
Offline Argus
    • pl Poland
      Bydgoszcz
  • Bydgoszcz Poland
I've died and gone to heaven.  :mrgreen: :mrgreen: thanks a million times over babis.  :cool: :razz: that sort of information you cant buy.
Offline babis_xo
  • 6* dummy
    • gr Greece
wow,I've done a similar search several months ago and couldn't find anything like that.  :-[
Online eye30
With all the info on this site I wonder whether the Hy techi check here first  for fixes  :lol: :lol:
Offline babis_xo
  • 6* dummy
    • gr Greece
 :lol:
My dealer already is.
Try "i30 TSB". Do you feel lucky? :wink:
Offline babis_xo
  • 6* dummy
    • gr Greece
"File unavailable" links updated. I feel very lucky today... I'm off for a lotto... :lol:
Offline babis_xo
  • 6* dummy
    • gr Greece
 :rolleyes: IF i could edit the 1st post, i would add:
17.06.2010  HGE09-12-P190-FD
Done... :mrgreen:
Offline babis_xo
  • 6* dummy
    • gr Greece
(Before starting to throw tomatoes and various veggies at the stage, let me explain what the following Kia Ceed TSBs have to do in our house)
After the info --> https://i30ownersclub.com/forum/index.php?topic=6719.msg83579#msg83579
posted by our new m8 (welcome Funky  :) ), i daresay that the several i30's steering column & EPS replacing incidents might be related to No KFE10-61-V030-ED TSB of... KIA.
I'm not aware of other "similarities" apart from this one, but AFAIK, i30 and Ceed are almost identical underneath.
So, picked (not exactly randomly) some Ceed TSBs, i hope needless for us:
2010.07.15  KCE10-71-V030-ED
                  FRONT END MODULE WIRING INSPECTION AND REPAIR (AMBIENT SENSOR 1, 2)
2010.06.11  KRE10-41-V060-ED
                  BRAKE MASTER CYLINDER (BMC) INSPECTION AND REPLACEMENT
2010.05.28  KFE10-61-V030-ED
                  (REVISED) STEERING COLUMN & EPS UNIT ASSEMBLY INSPECTION AND REPLACEMENT
2010.05.28  KFE10-41-V040-ED
                  (REVISED) WHEEL SPEED SENSOR ASSEMBLY INSPECTION AND REPLACEMENT
2010.05.28  KFE10-21-V070-ED
                  (REVISED) FRONT STABILIZER LINK ASSEMBLY INSPECTION AND REPLACEMENT
2010.05.28  KFE10-14-E180-ED
                  ECM UPGRADE - ED 2.0 EGR VALVE CONTROL LOGIC
2009.01.21  KGE09-13-P010-EDAMKM
                  FUEL TANK AIR FILTER INSPECTION & REPLACEMENT PROCEDURES (ED/AM/KM)
2008.05.27  KFE08-92-V161-ED
                  (REVISED) SRSCM CONNECTOR COVER REPLACEMENT
2008.05.22  KFE08-13-V040-ED
                  OXYGEN SENSOR INSPECTION & BURN OUT PROCEDURE (CEED 2.0 L BETA ENGINE)
2008.04.23  KCE08-92-V150-ED
               TURN SIGNAL LAMP SWITCH INSPECTION AND REPLACE
2008.01.30  KFE08-91-V040-ED
                  LEFT FRONT DOOR LATCH ASSEMBLY INSPECTION AND REPLACEMENT
2008.01.28  KFE08-14-P030-ED
                  ECM UPGRADE - HESITATION WHEN ACCELERATING
i would imagine that most of our i30's parts are the same as the KIA ceed.  :idea:
Offline babis_xo
  • 6* dummy
    • gr Greece
Let's hope that the faulty parts aren't the same :rolleyes:
If they are, then we have to be aware of the recall for Kia Ceed (KRE10-41-V060-ED), concerning the brake master cylinder.
Offline dani
    • bg Bulgaria
      Sofia
  • First Lesson. Stick em with the pointy end.
Do you know s.th. for ECM Upgrade?
I know, that CEED are upgrading their engines
Our engines are the same :)
Offline babis_xo
  • 6* dummy
    • gr Greece
Some sort of ECM's software upgrade for some 1.6L engines.
Actually they downgraded Ceed 1.4 (90hp from 109) :mrgreen:
Offline babis_xo
  • 6* dummy
    • gr Greece
Another KIA TSB. Applies to ceeds (and, probably, CERTAIN Czech i30s, like mine :evil: ) produced from April 1st 2009 until August 31st 2009, which might experience malfunction of the tail gate room lamp, noise and vibrations from the latch assy tail gate, due to poor contact of door latch while closing:
2010.12.01  KCE10-91-V250-ED
                  LATCH ASSY T/GATE INSPECTION AND REPLACEMENT
This issue has been reported in the past (relative posts #50 & #0)
* The above TSB is a countermeasure for customers complaining. Is anybody from Hyundai hearing reading?
Thanks Babis_xo :D
Yes, we have three actively browsing and five members in total (at the last count)
Offline babis_xo
  • 6* dummy
    • gr Greece
I think nobody is from Europe(?)
keep them coming babis.  :goodjob: :mrgreen:
Offline babis_xo
  • 6* dummy
    • gr Greece
A small update:
(only for i30s equipped with ESP)
Due to a unknown problem that I'm having with my brakes recently, I insisted that my dealer checks the BMC too, despite to his assertions that i30s are using a different part (note: he is a Kia dealer too).
Well, guess what: it IS the same part that is used on (Czech) i30s too.
Keeping in mind that Ceed's affected range was cars produced 'till 30-3-2009 and that the Czech factory started the production of i30s from 3-11-2008, maybe there is a possibility that some early produced i30s are having the faulty part (my dealer insists that there is no such a possibility, but I don't trust him any more, though I hope he is right).
The procedure of checking the BMC production date is an easy one and you could do it yourself in your own risk (just be careful when disconnecting the ECU connector cap because dealer "managed" to break mine).
P.S. just for the history: my July '09 produced i30 is using the updated part.
Some potentially useful stuff (TSBs etc) listed here for C'eed & i30.
Some in Russian, if that's your bag...
(thanks to eye30 for the links)
Administrator Comment Link removed as no longer online
Babis sent me an updated list of TSB's and I have replaced the original 1st post in this thread with his update...Thanks Babis  :goodjob:
Thanks nikitas (handy link with some limitations) :goodjob:
At least can get TSB numbers to quote to dealer!
