0 Members and 137 Guests are viewing this topic.
ok,got 2011 my crdi comfort,its done 1k miles,would give a puff of black smoke at startup but now white smoke. Done 140 miles left car for 6 hours,went to start car,glow plug light light went out,car started with mis fire,bv white smoke was awful,v embrassing on a 60 reg car{separated from original post}
thanks for the comments guys,re glow plugs first cold start of the day is ok,what with wrong service book and now this not happy with hyundai ownership
at dazzler,i have come out of a ford and no probs,im just aliule disappointed
what was the other one dazzler? and how did it rate?
Hopefully an expert will find the cause.I guess they will have checked the fuel filer for water.
oh oh i for got to say when my i30 puffs out a lot of white smoke in the morning more then any other day i notcied my rev counter doing little jumps like 700 to 800 down to 700 to 800 it does about 3 - 4 little jumps then stops at 700 and no smoke when it stops this only happens on cold motor so i dont know what the problem is other then that im really happy of my little i30 i called it duck lol im happy i got a i30 not a mitsubishi triton they are ***********PROBLEMS TRITON*****************father in-law has a 08 triton glx-r model and so many problems1. accelerator sensor stuffed up = new sensor + wiring2. knock in motor = replaced motor3. oil leak 3 times gearbox = new gaskets4. oil leak gearbox 4th time = new gearbox after making sounds over 80km/h5. very little ground clearance 205mm therefor drive shaft some how bent while 4wding = replaced6 .turbo shut off ok max power motor wont start after = new turbo 7. lucky he had warranty
Glow plugs replaced by dealer, but still got same problem, car goes in again next week, if they fail to fix, car will be rejected.
I always forget I've got glow plugs and start the engine straight away!however it starts fine,
