Glovebox Rattle
Mutley · 49 · 23481
Offline Mutley
  • Woof!
  • Fiery Red 2019 Premium!
    • Mutley Productions
Has anyone actually solved this rattle? I had a search but no answer of a solution.
Over 6 months ago someone mentioned something about gromets or plugs in the firewall under the dash needing to be pushed in tight to fix it but never got around to having a look..
You don't think this might be the same rattle (that just sounds like it is coming from the glovebox??)
Offline Mutley
  • Woof!
Possible but after I open the glovebox and close it, the rattle stops for a little while.
And if it's the same as mine it stops if you just leave it open. I think it's looseness in the hinge pivots.
Offline bumpkin
  • Keeping it in the family!
      Aberdeen
My glovebox has that buzz, solvable by putting less crap in the glovebox :rolleyes: :wink:
Either leave it open or turn up the radio  :lol: :lol:
Seriously now:
I remember seeing a bar at the left side which pushes onto a bar.
Check to see if it is fully home
Offline Mutley
  • Woof!
I've looked around but couldn't see anythign obvious.
The one that most annoy's me though is the one under/in the dash drivers side as it's constant.
I only ever had the buzz in the glovebox area but it was a constant annoyance.. I really should have tried to silence it early in my ownership period. Trouble was it was usually at highway speeds and I'd get home and forget about it until the next trip.. :rolleyes:
Is this a global thing :eek:
I have the occasional cringe but a quick open/slam shut solves it
It was a feature of my i30 I didn't tell Gowan's Toyota about.. :D
After driving my Hybrid demo around a bit I reckon it was the first thing the Salesman would have noticed when he took the i30 home for a spin.. They didn't test drive it during the trade in negotiations  :eek:
Offline Mutley
  • Woof!
Seems like it!
Also, the filter housing for the Air con is behind the glove box.
Could be that the filters are not fully secure.
it could even be the door you can slid open and closed for the chilled glovebox.  :idea:
Offline Mutley
  • Woof!
neither of those explain why opening and closing it stop it for a little while though.
Offline Mutley
  • Woof!
Dealer had it today but it didn't rattle so they couldn't do anything......
Don't you just hate that  :rolleyes: :P
Offline Mutley
  • Woof!
Yep! the little bugger went into hiding..
Offline agentr31
  • LOOK AT ME, LOOK AT ME!!!
i had a play with it today...
i think if you put a small patch of foam between the glove box (or one of those little stick on rubber pads) so there is a slight bit of tension between the glove box and dash it will go away... ill try something right now actually and let you know how it goes tomorrow!
Offline agentr31
well... i figured out what it is!
its the locking pins for the glove box... they rattle in the glove box door
my soloution that i am trying is, i have stuck 4 1cmx1cmx1cm patches of stick on foam on the glove box door
why, to put a bit of pressure on the door so it cant move, this putting a touch of preassure on teh locking pins and hopefully stopping the rattle!!
failing that it may be the mechanisim in the glove box door, if it is, i may look further into it, but i dobut it... it doesnt annoy me that much, i can live with it... *turns stereo up*
Do you mean I sold my Diesel for nothing  :rolleyes: BTW.. I think it is sold (not in the yard any more - I must check their website in case just moved to there other yard...) Edit: Moved to Burnie yard ... :lol:
P.S. You will be a Legend if you have fixed "that" buzzy rattle Ian  :mrgreen:
Offline agentr31
hahaha!!! *fingers crossed*
we will know tomorrow on my way to work if its fixed or not!
Offline Mutley
  • Woof!
I thought it might be that. Will try it. I really want to fix the other one that Ffoxy fixed though!!
carib
Hi.
I had that problem few days after pick up mine.
The locking pin nearest to passenger's door was not closing properly.
When I found that, I needed to close it several times strongly.
Actually it's perfect.
Regards,
carib
Offline agentr31
my rattle has gone!!!! now the car only really rattles when you labour it (trying to make things rattle)
Bit scary how easy that was to fix  :eek: (I have plenty of those sticky felt pads  :rolleyes:)
Offline agentr31
you want something thicker than a stick on felt pad!!
I'm feeling left out, my car doesn't appear to have any rattles as yet....Then again maybe I haven't noticed cos' I usually have the stereo blaring... :-[
Guess What?  :lol:
Trish's CW has that glovebox rattle too (otherwise the car is as tight as a drum) I am going to try the little rubber pads as per Ian's fix today..
Those sort of noises don't worry Trish but they drive me batty ( explains a lot doesn't it)  :rofl:
Offline bumpkin
      Aberdeen
:lol:
Just read this out to Kim, who agreed completely, must be a female thing, drives me round the bend and Kim sits oblivious!!
Sent from my 1000ET
carib
Guess What?  :lol:
Hi.
I don't need any rubber. See my previous post
Hi.
Regards,
carib
