Login
Register
Menu
Home
Forum
Search
Gallery
Help
Contact Us
August 26, 2026, 09:55:33
GENERAL STUFF
GENERAL DISCUSSIONS
Car Related (any make, any model)
Air Con Issue
Air Con Issue
Stevie J
4 ·
42
« previous
next »
Print
Pages:
1
Go Down
Stevie J
1st Gear
8
West Sussex
Air Con Issue
June 19, 2025, 09:40:21
So after having the Air Con on yesterday, it gradually ground to a virtual halt.. the air temp was good but despite fan on 4, almost nothing was coming out of all vents whichever. way I configured it.. It went back to normal after I turned off the air con button for a minute or 2 and then back on again. Is this a known issue please or the sign of something to come?
2016 i30
I30 GD
2nd Gear
80
United Kingdom
Re: Air Con Issue
Reply #1: June 19, 2025, 20:11:55
Did you have it on a low fan setting initially?
I30 gd
Stevie J
1st Gear
8
West Sussex
Re: Air Con Issue
Reply #2: June 20, 2025, 13:34:22
it was on 2 and toggling between 2 & 3... then it gradually blew less and less so I turned to 4, with very little air coming through.
2016 i30
I30 GD
2nd Gear
80
United Kingdom
Re: Air Con Issue
Reply #3: June 20, 2025, 19:34:38
It's called AC icing, I've had it before on a hot day on the motorway, it felt like the pollen filter was blocked.
If there's not enough air blowing over the AC matrix, it gets so cold that the humid air freezes and blocks the airflow, if you swith off the AC for a few minutes, the ice melts and it works as normal.
It's perfectly normal, nothing to worry about, 👍
I30 gd
Print
Pages:
1
Go Up
GENERAL STUFF
GENERAL DISCUSSIONS
Air Con Issue
Search
Username
Password
Always stay logged in
Forgot your password?
