i found this out at the petrol station one afternoon. :-[i locked the car to go in and pay for fuel,came out to fill the washer bottle. i reached in and pulled the bonnet catch an the horn started going off.
Quote from: 2i30s on November 14, 2010, 11:24:34i found this out at the petrol station one afternoon. :-[i locked the car to go in and pay for fuel,came out to fill the washer bottle. i reached in and pulled the bonnet catch an the horn started going off. door unlock doesnt work when the car is locked...I take it you left the window open so that you could reach in and release the bonnet without unlocking the car again??That then raises the next obvious question, what was the point in locking the car with the window open, you only have to reach in and unlock the door with the button if you are a tea-leaf on the lookout surely
well locked with the remote... obviously it works when the car is running
Quote from: bumpkin on November 14, 2010, 11:59:05That then raises the next obvious question, what was the point in locking the car with the window open, you only have to reach in and unlock the door with the button if you are a tea-leaf on the lookout surely On mine the locks are DEADLOCKS and can't be opened by moving the lever.The only way to open the door is with the remote or by using a key in the key lock.
Quote from: eye30 on November 14, 2010, 12:18:09Quote from: bumpkin on November 14, 2010, 11:59:05That then raises the next obvious question, what was the point in locking the car with the window open, you only have to reach in and unlock the door with the button if you are a tea-leaf on the lookout surely On mine the locks are DEADLOCKS and can't be opened by moving the lever.The only way to open the door is with the remote or by using a key in the key lock.Not the lever, the door lock button on the armrest.
My brother reckons his used to go off while he was cleaning it His alarm that is....
Ok this is my updateWhilst out this pm sitting in the car I removed the key from the ignition switch.Locked all doors with remote.Could not open door as the deadlocks had activated.Door would not open by pressing the switch on arm rest.ConclusionOnce my car is locked via the remote the doors will not open by pulling the door lever or by pressing the switch on the arm rest.So even if window is open the only way into the car would be to crawl thro' the window
LOL!!! you guys are mad!
Quote from: eye30 on November 14, 2010, 18:04:11Ok this is my updateWhilst out this pm sitting in the car I removed the key from the ignition switch.Locked all doors with remote.Could not open door as the deadlocks had activated.Door would not open by pressing the switch on arm rest.ConclusionOnce my car is locked via the remote the doors will not open by pulling the door lever or by pressing the switch on the arm rest.So even if window is open the only way into the car would be to crawl thro' the windowCool, thanks for trying that out.Conclusion - 2i30's has the longest arms you have ever seen, cos he can release the bonnet through the drivers window without unlocking the car
maybe I have short arms
