High beam not working
Guest · 8 · 6101
druggist
I changed the bulbs in my CW HDi today to Osram night breakers. Neither high beam bulb is working. I've tried both old & new bulbs. I've only had the car a month and am not sure if they ever worked. When you "flash" your lights low beam comes on as well and I am not sure if I have just seen low beam when I was driving and flashed lights. Blue light comes on dash.
I've checked fuses, and haven't got time to take it back to dealer this week.
Have I missed something obvious?
Is bulb OK?
It may have been duff when you bought it.
Is bulb OK?
  he's upgraded the originals,buy doesn't know if they were working to start with.
druggist
Managed to get into local service department today.
problem fixed "Checked Earth Points as required. Found earth at both globes not present. Repaired loose earths"
whatever that means.
More of a concern was the service managers comment that diesel i30s are blowing headlight bulbs due to a surge produced by the alternator at startup. Made worse if you leave lights on, with auto On/Off.
They might replace alternator after 3 or 4 return visits if problem doesn't resolve.
Anyone at Hyundai care to comment. Local service isn't the best here on the upper north shore of Sydney.
Hopefully one of our insiders will see this thread but it does appear to be more common in the diesels come to mention it.. Myself, Shambles and a couple of other diesel (or previous diesel owners) have upgrade bulbs only to have them blow quite quickly.. :idea:
My first set of Philips + 50 (I think they were) blew after only a month or so (both at once) and they said at the time it looked like they had possibly sircumbed to a surge but fortunately they replaced them under warranty.. the repacements lasted longer but not long enough! :mad:
Many others haven't had any problems though...
druggist
I was having an issue with my new i30 cdi CW with high beam not working. Apparently "Earth was adrift at headlights" since new.
The service manager let slip that diesel i30s are having a problem with a power surge caused by the alternator at start up, causing headlights to blow, especially when headlights left in auto-on position.
Anyone had the problem?
Offline henno77
    • ie Ireland, Republic of
      Ireland
There have been a few reports of an earth fault "behind the battery" causing bulbs to blow, but I've seen those mostly on a different site.
Do you have the Bosch active battery recuperation? (check for a temporature sensor on the battery terminal) becuase if you do this will show strange volatge readings as you start up.
My "extremly sensitive" nightbreakers lasted 13 months OK on mine, and then just one blew, I think whilst I was driving.
<Topics Merged>
