Login
Register
Menu
Home
Forum
Search
Gallery
Help
Contact Us
August 24, 2026, 17:17:58
THE GARAGE (SERVICE, MAINTENANCE & REPAIR)
DIESEL
Diesel oil
Diesel oil
pawl007
15 ·
6758
« previous
next »
Print
Pages:
1
Go Down
pawl007
2nd Gear
30
Diesel oil
April 23, 2011, 05:18:25
Hi Everyone
The good missus and myself are going on a belated honeymoon trip through the east and south west of West Oz. Heading off on Monday at 9am and today I thought I would check the oil, water, air etc. Noticed the oil is half way between full and low and thought I would give it a top up because the trip will be approx 3000 km. Problem is that the Hyundai service departments are all closed and now I don't know what oil to top it up with. Easter time and only a few auto places are open. Repco is and a few others. The car has done 10000km and still has 5k to go until its next service. Does anyone out there know which diesel oil should go in there? The last thing I want to do is put in something that will damage the motor. I suppose it will be ok to leave it but would prefer to be top it up.
AlanHo
Global Moderator
Geriatric Teenager
21,468
England
2021 KIA Niro 3 1.6 Petrol Hybrid
Re: Diesel oil
Reply #1: April 23, 2011, 05:42:41
Read through this thread or search this forum for other threads on engine oil...Your service handbook will specifiy the correct oil specification for your engine
https://i30ownersclub.com/forum/index.php?topic=8560.0
2021 KIA Niro3 1.6 petrol Hybrid
pawl007
2nd Gear
30
Re: Diesel oil
Reply #2: April 23, 2011, 07:35:11
Yes thanks a lot but when I look through the specs it it gives 2 options; one for a vehicle with a catalyzed particulate filter and the other for one without. How will I know if mine has a CPF or not?
AlanHo
Global Moderator
Geriatric Teenager
21,468
England
Re: Diesel oil
Reply #3: April 23, 2011, 09:04:16
Does it not tell you in your handbook what oil is appropriate.
If not - the safe bet is to assume the engine has a CPF
2i30s
Top Gear
12,402
Australia
Re: Diesel oil
Reply #4: April 23, 2011, 09:36:10
did you have the oil changed at 7,500kms? you could check the invoice to see what they used.
2009 manual sx hatch and 2009 automatic sx cw. both 2.0 petrol.
pawl007
2nd Gear
30
Re: Diesel oil
Reply #5: April 23, 2011, 10:35:25
No, we were under the impresssion that after the initial service at 1000km that the next one is at 15000km.
Also there is nothing in the handbook to say whether my vehicle has a converter or not
pawl007
2nd Gear
30
Re: Diesel oil
Reply #6: April 23, 2011, 10:37:51
Sorry I mean CPF
eye30
Global Moderator
HOS BOSS
27,423
England
Wirral, UK. - 1.4 Petrol Active - Aqua Blue
Re: Diesel oil
Reply #7: April 23, 2011, 11:26:04
In Uk Castrol have this site:
http://www.castrol.com/castrol/castrolhomepage.do?categoryId=3205
and I've found similar site for oz.:
http://www.datateck.com.au/lube/castr_au/default.asp?categoryId=8000001
1.4 Petrol Active I'm no expert, so please correct me if
Dazzler
Admin
Laughter is the best medicine...
67,423
Australia
Best Car Forum on the Net
Re: Diesel oil
Reply #8: April 23, 2011, 11:48:49
That's very interesting Lester for the CRDi (in OZ at least) it only gives the Castrol edge 0-W40
not the 5-W30
2021 MG PHEV ( had 4 x i30 plus a Getz an Elantra and a Tucson)
2i30s
Top Gear
12,402
Australia
Re: Diesel oil
Reply #9: April 23, 2011, 11:57:33
it also gives crdi automatic, and crdi manual. i wouldn't have thought the engine oil would be different because of what gearbox you have.
rustynutz
Top Gear
17,513
Australia
Re: Diesel oil
Reply #10: April 23, 2011, 13:41:14
pawl007, it would be safe to use something like Castrol's Edge 5W 30 or even Nulon's equivalent in your i30. They are both usually available in 1 litre bottles.
You don't have to worry about any particulate filter as the Oz i30's don't have one fitted.
pawl007
2nd Gear
30
Re: Diesel oil
Reply #11: April 23, 2011, 14:51:10
Thanks a lot all and sundry. Rustynuts, that sounds good to me. Will have to get a bottle in Kalgoorlie. Cheers.
Re: Diesel oil
Reply #12: April 25, 2011, 01:17:20
You will not hurt anything by using any engine oil as a top-up; even dino oil. Much better to be full than low, although the low mark is still a safe level.
AFAIK all (?) Oz cars say ACEA B4 near the filler cap. Any oil that meets that (look on the container) is exactly what is required. As far as viscosity goes, w30 or w40 would be fine, not w50.
Surprising to have used much oil in so new a car though. If anything oil consumption shoud reduce as the engine beds in so it will probably improve. While you have the book out, just verify you do not drive in the "harsh" conditions that suggest you ought change the oil every 7500Km intervals.
I guess you have already gone now... so I hope you enjoyed the trip.
Doggie 1
Top Gear
Doggie Connoisseur
31,103
Australia
2019 PD2 Go Petrol, Manual. 30,000 kms.
Re: Diesel oil
Reply #13: April 29, 2011, 13:06:04
My crdi has a sticker under the bonnet that says "This vehicle is not fitted with a particulate filter" or words to that effect.
And by the way, when I initially asked the service dept of John Hughes what oil they used they were unable to tell me. They just said it was a "blend" that they buy in bulk which didn't fill me with confidence.
Which is why I have always used their mobile service facility and have supplied my own oil so I know what goes in there.
I use Shell Helix Ultra with the correct specs for the diesel engine.
Tertius the i30
2i30s
Top Gear
12,402
Australia
Re: Diesel oil
Reply #14: April 30, 2011, 01:13:12
my dealerships service dept uses shell oils now,the castrol magnatech wasn't cutting the mustard apparently.
Print
Pages:
1
Go Up
DIESEL
Diesel oil
Search
Username
Password
Always stay logged in
Forgot your password?
