Surferdude's New Tyres
Surferdude · 118 · 37131
Bump.
Got almost 82,000 klms up now. Measured the tread depth today.
All 4 are at 3.5mm.
So. About 53,000klms from them so far.
I'd normally go to about 2.5mm but I'll do something about these by the end of the year.
Been pretty happy with them. Extremely good grip in the dry and on loose surfaces. Predictable in their handling.
Slightly less so in the wet but I'm not sure how much of that is the car's characteristics. I'll know when I replace them.
Sounds like you are considering trying something else next time Trevor?  :cool:
Still a Goodyear Dazz. Efficient Grip or Excellence.
I have both.   :D
I have both.   :D
  :question: :question:
He's talking about his hand on his willy...  :lol:
Offline Paolo5
My diesel i30 is just about to click over 70,000km. The original Hankooks are still hanging in there....but won't for much longer.
I can get the correct tyres 205/55R16 in the Duraplus for $135 each (buy 3 and get the 4th one free until 31-12-15).
Just wondering if there would be a better tyre around now...
I had the Durapluses fitted to my Getz (at Trev's recommendation) about 45,000km ago and they are fine. Thanks Trev!
Thanks for the feedback Paolo. Always good to hear.
The 443 is a good deal when it's on.
I'm probably due for some new ones this year. I'm going to try the Efficient Grip. It's available in your size too. Might be worth asking for a price to compare. Otherwise, stay with what you're happy with. The Duraplus certainly gives good mileage.
:link: EAGLE EFFICIENTGRIP, Goodyear, Australia
Otherwise, the Assurance Armorgrip might be a go. Its tread pattern suggests a bit better in the wet, but "maybe" fractionally less wear.
:link: ASSURANCE ARMORGRIP, Goodyear, Australia
Offline Paolo5
Thanks Trev.
I think that I will stick with the Duraplus tyres.
Cheers,
Paolo
Offline Paolo5
Here is one for you, Trev....hope that you can advise me...
I had 4 Dunlop Duraplus tyres fitted yesterday. The original tyres were on the car for 70,034km...which I am happy with.
I was going to leave the rears on for another 10,000km but it was pointed out that the inside edge of the driver's side rear tyre was smooth....and wouldn't have passed rego.
I have always rotated radial tyres front-to-back every 10,000km.
The Duraplus is an asymmetrical tyre that is non-directional. What I am wondering is whether it would be better to rotate them front-to-back
or
fronts to straight back and rears to cross over to opposite fronts.
My thoughts are that if I had rotated the way mentioned above, this wear mentioned above would not have concentrated on this one tyre. Is this flawed logic? Which is the best way to rotate for this particular tyre....and what pressures should I run? (I have always used 40psi (cold) front and 36psi (cold) rear.
Thanks,
Paolo
« Last Edit: January 04, 2016, 21:35:55 by Paolo5 »
or
My thoughts are that if I rotate the way mentioned above, this wear mentioned above would not have concentrated on this one tyre. Is this flawed logic? Which is the best way to rotate for this particular tyre....and what pressures should I run? (I have always used 40psi (cold) front and 36psi (cold) rear.
Thanks,
Paolo
"Goodyear" Duraplus.  :P
And yes, Rotate them as per your second option. ie. Rears cross over to opposite front.
Cheers.
Offline Paolo5
Thanks Trev,
My Getz "Goodyear" Duraplus tyres have now done 45,000 km. I will rotate them as per plan B next time.
What pressures would you advise for my diesel? (Mainly highway kilometres with just driver on board.)
Cheers,
Paolo
Thanks Trev,
Cheers,
Paolo
I run mine at 36psi all round. It's a petrol but most of the guys on here seem to go with around 36 on their diesels.
Offline simon@mgr
      Ingham, FNQ
I run 40 front & 37 rear
  • 2008 FD 5 Door Hatch, Diesel 1.6lt, Manual, Grey
And I run 38psi all round with my diesel...  :)
41 all 'round. Still original rears at 84,000. Fronts lasted to 65,000 due to uneven wear from misalignment.  :rolleyes:
36psi was what I ran with standard Hankooks, 38psi now with the 18"s.
I replaced the Durapluses today.
Got a bit over 56,000 klms out of them with still about 4mm on them all. They were quiet, rode well. I never rebalanced them after the original fitting. Nor did another wheel alignment  :-[
If I had to find a down side to them, they probably could have been a bit better in the wet on roundabouts. Pushing hard (too hard??) brought in a touch of understeer.
Gone with Goodyear Assurance Triplemax.
I'll keep you posted.
Can't tell you the price or I'd have to kill you.  :mrgreen:
Wheel alignment was still close to specs.
Tread pic
Fitted
Offline Paolo5
I had my original tyres replaced with Goodyear Duraplus tyres just over a month ago...no complaints but an observation...
According to my TomTom, with the original tyres the speedo was spot-on through its range.
With the Goodyear Duraplus tyres, when the GPS reads 110kph, the speedo reads 114kph.
My Getz suffered the same glitch when going to the Duraplus tyres several years ago.
Has anyone else noticed a speedo becoming less accurate after changing to tyres of a different brand and type (but the same size)  to those fitted as original equipment?
I would rather the speedo over reads, which is much more common than dead accurate, but I see where you are coming from. ..
Interesting observation.
The specs of all tyre sizes are governed by guidelines which allow for small variances in design but they must conform to be within certain minimal variances. These are set and overseen in Australia by the Australian Tyre and Rim Manufacturers Association. There are similar bodies in North America, Europe and Japan and generally the dimensions are the same.
Given a tyre size - say 195/65R15 which fits my car, the 195 is the width in mm between the extremities of the sidewalls (inflated to a set pressure and allowed to stand for a period - I think 24 hours) (Oh. And on the "design" rim for the size. ie. The optimum fitment). The 65 is 65% of the width which should be the height between the tread and the bead where it mounts on the rim. It's not much but the other factor is the difference in diameter between a new tyre and one which is worn out.
So, if a manufacturer makes a tyre which is say, 192mm wide, it's 65% will be less than the one which is maybe 197mm wide (both within tolerance for design). In theory, the manufacturer should adjust the 65% marginally to allow for this but maybe that doesn't always happen.
Hope I haven't lost you. And the above is a pretty simplified explanation of the whole process.
But this could explain the difference you're seeing.
In every car I have owned the speedo has always been between 5 and 10% fast.  I have never known one to be dead accurate.
10% is enormous.
I must admit it's only the last couple where ive tried for accurate comparisons, but they've been a bit under 5%. We used to run checks on our Halda trip meters for rallying but that was for distance and I always assumed any variance in the speedo was reflected in the odometer.
IIRC my runs through the Ballarat max 117 meters registered 106 for my speedo's 110. That makes it (110-106)/110=4/110=3.6% :goodjob:
Police pursuit cars over here have calibrated speedos (not Speedos) so are accurate.
But most others I've driven are optimistic.
One of my cars reads under though so need to be careful.
I wouldn't take those speed check readings as gospel, Gonz...
http://www.heraldsun.com.au/news/victoria/drivers-confused-by-electronic-speed-advisory-signs/news-story/0a2f7f05d37047ea6e91f07d4054d41d
