0 Members and 11 Guests are viewing this topic.
Has anyone else noticed their clock on their radio gaining time? My i30 SR gains about 1 1/2mins a week which is carp considering its a month old. My mates I30 trophy does it too and its only 6 months old. Anyone else noticed this? Can something be done under warranty?
Set the clock to radio time. This uses the radio time signal to keep accuracy.
My wrist watch also receives the Greenwich time signal from Rugby ...
Finally got my clock set up with the auto option. Needed to get the manual out to find what to do.
prompted by this thread I decided to check my car clock against the Greenwich time signal emitted from Rugby and damn it not accurate, it is three seconds slow............
Quote from: asathorny on September 26, 2011, 09:34:45prompted by this thread I decided to check my car clock against the Greenwich time signal emitted from Rugby and damn it not accurate, it is three seconds slow............That's the problem you see. Your time signal (just like mine) is coming from Anthorn in Cumbria, not Rugby any more
I'll try from memory. Press setup. Select clock turning the folder knob to move to menu items. Press to select clock. The time displays & you use folder to change time then press folder to set the time. Hope I got it right.
My book set includes the radio manual for the bluetooth version. From memory press and hold the volume button and turn to change setting options. It's either under the settings menu or a menu item of its own. Once in time set mode, turn the volume nob to change the highlighted section, push to highlight next item to change. Let me know how my memory performed Lakes
