Ever since deregulation, which happened before we moved back from Sydney we've been pestered by door to door salesmen, offering great deals if we'd switch to origin Energy. They really are very pushy and annoying <.
Quote from: surferdude on March 19, 2012, 10:38:46Ever since deregulation, which happened before we moved back from Sydney we've been pestered by door to door salesmen, offering great deals if we'd switch to origin Energy. They really are very pushy and annoying <.So you could actually understand these ones?
Quote from: rustynutz on March 19, 2012, 12:43:48Quote from: surferdude on March 19, 2012, 10:38:46Ever since deregulation, which happened before we moved back from Sydney we've been pestered by door to door salesmen, offering great deals if we'd switch to origin Energy. They really are very pushy and annoying <.So you could actually understand these ones? Not a word .... which was a giveaway in itself. But they held up their ID cards which had "Origin Energy" on them, right in front of their shirts with the same logo on them.
Just found this Trev.. Can tell your inverter is fancier than ours (we only have a small readout that scrolls but prefer our grey coloured casing ) Trish would have had a fit if ours was that colour ..
No offence met but Trish has a thing about colour .. She was disappointed ours wasn't cream like our Meter box and trim.. But the Grey colour blends in ok.. I thought the SMA ones (which are supposed to be top quality, were generally brighly coloured)
@Dazz@surferdudeAre you chaps keeping records of your solar output. I record mine weekly using my phone to remind me. I measure Total Kw generated and our weekly consumption of Std power, Off peak and Net grid return. I intend to slightly modify my system in about 12 months. The data I collect now, will form the baseline data (a bit small though, I admit) I think I can get 5%+ improvement. If you had 12 months of data & were interested, you could possibly gain as well
Well, heat is a great killer of panel efficiency. It is possible to have heatsinks fitted to the rear of the panels & apparently they work, I'm not out to spend any more on my system though, so not going to do that. In summer I had a good look at most panel installations and IMO, all of them are fitted to a price. Due to roof space limitations, I only have about 40mm between the panels. They are mounted on 2 aluminium tracks approx 100mm from my tiled roof. Naturally, the surface of the panels is black, bad news in Summer and prone to solar heating. The mid section of the panel has little to no ventilation due to tracks bottom & top.I propose to insert aluminium spacers onto the tracks & lift the panels. The heating of the panels should create a convective flow of air from bottom to top, unimpeded by the rails. Cost would be the spacers & longer bolts. I figure they will run cooler & make more juice.
Heat probably not as much of an issue here in Tassie..
I don't understand the ventilation issue. Our panels sit about 100mm above the roof. They are in two rows of 6 panels. Each panel is separated from its neighbours by a gap of probably 30 - 40mm. The rails they sit on )IMO) channel any airflow between the roof and the bottom of the panels. So I'm guessing your installation is similar to mine.
Quote from: surferdude on May 24, 2012, 11:02:37I don't understand the ventilation issue. Our panels sit about 100mm above the roof. They are in two rows of 6 panels. Each panel is separated from its neighbours by a gap of probably 30 - 40mm. The rails they sit on )IMO) channel any airflow between the roof and the bottom of the panels. So I'm guessing your installation is similar to mine.So your rails are mounted vertically, mine are horizontal.
