My new DOD F500LHD
Shambles · 87 · 25849
Ok. thanks for that.  This camera seems to be quite good and personally for the price is not expensive at all.
My DOD runs all the time I'm driving, but to be honest I've got absolutely nothing worth viewing. No incidents. Nothing.
Maybe I should reinstall my old camera :lol:
Which reminds me, I must get some practice in using MovAvi (thanks misha) as the first (and only) time I tried it I ended up converting a 20 second edited clip (from the DOD) into a 1Tb avi file :eek:
Offline meehalych
  • Aircraft technician
    • ru Russian Federation
      Kolpino
did you convert it into 3D?   :lol:
Oops  :-[
Are either of you two guys planning to upload a video?
I see a model F520LHD, wonder what the difference is.
I've been checking that one out, pip....Seems it's an updated model to the F500....
It supports 64gb SD Cards, uses no interval time file saving technology, takes 16mp photos and comes in a pretty gold colour....  :D
Yes, I saw those features but hadn't ascertained what was different to the 500 model. Makes it even better and ebay has reasonable prices. :D
Offline meehalych
      Kolpino
the last DOD F500's software provides no interval time too, so there is only one significant difference - colour
the last DOD F500's software provides no interval time too...
Very interesting. Mine has time intervals though the time it takes to switch files is less than 0.5 second, unlike the 10 seconds my previous camera took.
Must look for any later firmware for my doddie; I'm using v7.3 T2L-HH
So the firmware has bumped the SD card support up to 64gb for the F500?
And still pics up to 4608 x 3456(JPEG)?
What about the digital zoom...it's 8X on the F520...compared to 4X. :undecided:
Offline meehalych
      Kolpino
I can't see a sense in using SD cards with hight capacity, such as 64Gb for example (unless someone wants to record a really long trip in one go with no notebook or other storage device at ones disposal).
do you really need the digital zoom?! is it so vital feature?  I would prefer to have optical one instead
:whsaid: no need for any kind of zoom, if all you're doing is recording the road trip :)
Misha, have you found any later firmware version for your doddie?
Offline meehalych
      Kolpino
here is a page with all firmwares and compatibility
https://docs.google.com/spreadsheet/pub?hl=en_US&key=0AvvapV-CkhvkdGxHdFBkdTRvdGZiRkhNd2NjanhIcEE&hl=en_US&gid=5
the latest one there is V8.9 T2L-KH     (mine is 2.51 T2L-KH)
Thanks. Not sure I understand any of it
Offline meehalych
      Kolpino
I have just updated a firmware of my DOD successfully.
Here is a procedure for you:   Make sure you didn't mistake while writing down your firmware here as it has to be v7.3 T2L-KH
-download a file from here http://f500-faq.narod2.ru/firmware/F500L_update_files_v2_4.zip
-further on you will have to download a desired firmware
-then you will have to format your SD card by either camcorder or PC
- insert SD card into a cardreader and copy "autoexec.ash" file from "F500L_update_files_v2_4/update" folder (the one you have downloaded in step one) and a desired firmware
- you will have to rename a desired firmware file into firmware
- remove SD card and insert it into camcorder and turn it on
- wait for at least one minute (although 10 seconds are said to be enough)
- turn your DOD off
- insert SD card into a card-reader and make sure two previously mentioned files disappeared and flashlog.txt was recorded (it may be deleted)
- now you may insert SD card back into DOD and use it
No interval between files detected.
A static picture when DOD is on and off has been swapped to Mystery one
I'll try all that thanks :D
Any idea what the differences are?
Just rechecked my firmware using a magnifying glass and it is indeed T2L-KH (not -HH)
Offline meehalych
      Kolpino
there is no time interval between files (it was 2 seconds in my former firmware)
Well I'll give it a shot right now.
Which firmware did you choose? I've got
http://f500-faq.narod2.ru/firmware/500/4x/V8.9_T2L-KH.bin
Offline meehalych
      Kolpino
this one too
keep in mind:
there is also the fastest way of firmware update (it didn't work in my case):
- download a desired firmware
- rename it into yamaha
- insert SD card into camcorder
- turn DOD on and do not turn it off until "firmware update" note disappears (10 seconds)
- turn DOD off, insert SD card into a card-reader and delete yamaha file
« Last Edit: May 13, 2012, 17:32:57 by meehalych »
Who has provided these firmwares? I've got my SD card ready but haven't started it yet
Offline meehalych
      Kolpino
camcorder owners (they also tested a firmware compatibility with older firmwares)
Well, the flashlog.txt file was created with a few bytes of rubbish in it, but the "firmware" file remained.
And the version on the camera settings remains as it was before :(
You sure I have to rename the file to "firmware"?
Offline meehalych
      Kolpino
yes, to firmware (I hope you disregarded these "")
from V8.9_T2L-KH.bin to firmware.bin  or, how it appears in a folder from V8.9_T2L-KH to firmware
firmware.bin
not firmware :rolleyes:
I'll try again :P
Offline meehalych
      Kolpino
firmware.bin
I'll try again :P
It didn't work, when I renamed file into firmware.bin, actually (though a text file was created too)
Did you copy this too?:
autoexec.ash
Offline meehalych
      Kolpino
if it doesn't help, try the fastest way, described earlier
Yep got the Mystery logo.
Not much else seems to have changed.
I've got "duration" settings as 45min 30min 15min and "recycle" as 15min 10min 5min and 1min (and "off")
Offline meehalych
      Kolpino
"duration" may be set to "off"
Not that much of an upgrade then :(
Cheers anyway
Offline meehalych
      Kolpino
Cheers anyway
come on, there will be other updates later on, no doubt
at least I got rid of that 2 sec interval  :happydance:
