DPF regenerating problem
Asterix · 50 · 29310
Mine is 2008 (Korean built) and has a DPF
Thanks Steve - I stand corrected. However - I know of someone with a March 2010 Czech built i30 that does not have a DPF.  When my previous car arrived in September 2010 the dealer was not sure whether it would have a DPF - I was hoping it didn't - but it did.
...the dealer was not sure whether it would have a DPF - I was hoping it didn't - but it did.
If I might just stray a little left of topic here, one of the three dealerships I've used for a service actually asked me if I had a DPF fitted, when I queried the semi/synth engine oil they'd filled her with. I had to pop the lid and point out the device to them.
I believe The u series engines got cpf built into the exhaust downpipe rather than dpf which is big and obvious near the Turbo.  surly no 2008 diesel i30 would have a dpf requiring regeneration.
BOTH  low smoke oil.
What a confidence booster.  :Shocked:
My '09 in Australia doesn't have one and the new model Crdi that I looked at yesterday at the dealership didn't have one either.
A DPF is necessary in Europe to meet the strict emission regulations applied here. Perhaps Australia does not have the same standards and a DPF is not necessary.
Do you Aussies suffer from irritating coughs by the way......... :whistler:
Not personally, although there has apparently been an increase in the number of kangaroos and koalas with bronchial infections  ;)
No, we have wide open spaces & intelligent population numbers. This is why all the convicts were laughing as they sailed past lands end.  :mrgreen:
No, we have wide open spaces & intelligent population numbers. This is why all the convicts were laughing as they sailed past lands end:mrgreen:
.. until the Irish turned them round and said "it's the other way --->" :P
Offline Rogmur
      West London
  • Our i30 With no one else around
Hello to everyone,
I found this interesting Website regarding DPF, hope it is useful.
http://www.aa-academy.com/Training/Learning%20Zone/Diesel%20Particulate%20Filter%20(DPF).asp
We have a 2010 1.6 CRDi with DPF and I often worry if I am taking the car for long enough journey's to burn off the soot.
Surely, if the i30 did not have a DPF installed the road tax (in UK) would not be £30?
Kind regards to you all
Rogmur :wink:
Thank you Rogmur .. very interesting
Just an update on this thread.
2 weeks ago the dealer cleaned the DPF with something they call a "waterpipe". They put in some foam to dissolve the soot in the DPF, leave it for some hours and then flush it out. That didn't solve the problem.
The dealer have now replaced 2 temp/pressure sensors, 1 located in the turbo, and 1 in the DPF.
I have now done more than 100 km since this repair, and the engine control light haven't flashed yet. Before the repair the engine control light would have started flashing only a few kilometers after resetting the fault code.
The sensors cost around 300 EUR a piece, + all the hours they've spend locating the error and replacing the sensors. I'm not looking forward to receive the bill..  :blubber: :blubber:
I really hope this is the end of this  :scared:
Offline xreyuk
      Southport
  • Seat Leon 1.6TDI CR Ecomotive Owner
It's quite common VAG cars for sensors to fail, however, these usually cause more regens.
I'm not sure how the Hyundai ones work, but the VAG cars do pre-planned regenerations anyway between 400-700 miles, regardless of soot content.
The only thing I would say, DPF's aren't usually covered under warranty. What a lot of the VAG group guys do is drive with the DPF until it gives them problems, and then have it deleted and given a remap to get rid of errors. That costs around £500 where as a new DPF costs easily over £1,000.
It actually did regenerate more often than usual.
At last the engine control light started to flash, and I thought the DPF wasn't able to regenerate, but given the faulty sensors, it wasn't the DPF that was faulty, but I suspect the ECU to start the regenerating again and again due to wrong signals from the sensors.
Now 150 kilometers without flashing light..  :happydance:
What do you mean with deleted.. :question: Do they remove the DPF.. :question: If so, what do they do when it's time for the MOT.. :question:
Have now done more than 1500 km since the repair, including 200 km with the caravan, it's all fine.  :happydance:
(But I had to pay 1100 EUR / 900 GBP / 1360 AUD)  :blubber: :blubber:
If any of you guys ever have the engine controllight flashing, and a fast trip on the motorway doesn't solve the problem, make sure to have the sensors checked.
According to my local dealer they have never had this problem before, and neither had the Danish Hyundai service dept.
 :faint: :fum:
That is a lot of money Asterix! (I guess I'm not telling you anything)  :(
You will need to keep the car another few year now to get your money back... :Pout:
