Volunteer required for Google Map Updating
Dazzler · 23 · 5586
Hi Everyone...
Encountar who has done a lot of work adding members to the Google Map section has unfortunately been swapped with other commitments. (thanks for your efforts so far Petey)
So... we now require a volunteer to take over his duties (He will be happy to provide access and instructions to someone who can update the map on a regular basis - maybe weekly?)
I (for one) would be happy to help the person to identify locations of those regular members who are not yet shown on the map.
I guess first genuine offer gets the job! Does that sound fair?
Cheers,
Dazz
Offline Hemmi
    • is Iceland
      Reykjavik, Iceland
Hemmi can do it :)
Offline Rubix
Offline GURKHA17
      Darwin
  • Darwin,NT, Australia
I vote for Hemmi
Hi Hemmi,
Funny, but I thought of you when I did the posting... sounds good to me  :D
Just P.M. Encountar to get his admin rights..
Offline encountar
      Penrith
Hemmi has been added as a mod of the map.
Thanks very much for your assistance Hemmi :) I'm sure everyone here shares the same opinion
ouri30
It's occured to me that Hemmi, being at the top of the world, so to speak, is in the ideal position to oversee the location of all the members.
Bob
Offline Hemmi
    • is Iceland
      Reykjavik, Iceland
Bob
 :lol: yes, maybe I'm the northern most member  :)
My latitude is 64°North  :wink:
Offline bumpkin
  • Keeping it in the family!
      Aberdeen
You are definitely the furthest North Hemmi, my plan tells me so, after that it's me and then you can follow my trip which so far has been pretty much North-South so far. :D
Offline Rubix
On that note, can you fly over the north/south poles?I see most planes travel around the world but don't hear anything about them flying over the poles. Is there any location where flying over the poles would be faster than flying around the horizontal axis??
Offline bumpkin
      Aberdeen
Hi Rubix
It is possible to fly over the poles in the real world, however the flight sim series restricts the budding flyer as scenery stops at about 80 degrees. :'(
In the real world, most trans-Atlantic and Pacific flights, do not straight line as due to the curvature of the earth this would be longer so for instance a flight to New York from London actually curves past Iceland and Greenland to reduce the distance travelled and therefore fuel used, time required etc....
Hi Brian..
I'm trying to get my head around that concept. They fly in an arc to avoid flying in an arc... :eek:
Offline bumpkin
      Aberdeen
Yup :lol:
The arc around the centre of the Earth is longer than the arc 10 degrees higher or lower than the equator which is again longer than another 10 degrees higher or lower than that, so the route from a-b is plotted as an arc of least distance.
Here is a planned route (for flight sim purposes) from Newcastle UK to New York
EGNT             0      0   N55°02'15.00" W001°41'30.00" NEWCASTLE
TLA     113.8  303     63   N55°29'57.00" W003°21'10.00" TALLA
MAC     116    275     78   N55°25'48.08" W005°39'01.49" MACHRIHANISH
RUBEX          270     44   N55°19'12.00" W006°56'07.00" RUBEX
EGEI2          269     53   N55°10'15.00" W008°27'42.00" EGEI2
NIBOG          269     54   N55°00'00.00" W010°00'00.00" NIBOG
ODLUM          281     69   N55°00'00.00" W012°00'00.00" ODLUM
RESNO          283    103   N55°00'00.00" W015°00'00.00" RESNO
56N020W        304    180   N56°00'00.00" W020°00'00.00" 56N020W
57N030W        300    336   N57°00'00.00" W030°00'00.00" 57N030W
56N040W        286    336   N56°00'00.00" W040°00'00.00" 56N040W
54N050W        281    364   N54°00'00.00" W050°00'00.00" 54N050W
CARPE          279    156   N53°05'00.00" W054°05'00.00" CARPE
REDBY          270    104   N52°14'58.00" W056°36'06.00" REDBY
YNA     113.6  266    231   N50°11'01.18" W061°46'51.83" NATASH
CL      207    261    225   N48°00'32.00" W066°26'13.00" CHARLO
TAFFY          245     52   N47°22'24.00" W067°18'14.00" TAFFY
PQI     116.4  243     48   N46°46'27.00" W068°05'40.20" PRESQUE ISLE
FRIAR          228    159   N44°26'28.93" W069°53'04.38" FRIAR
ENE     117.1  225     69   N43°25'32.40" W070°36'48.60" KENNEBUNK
KJFK           238    219   N40°38'23.40" W073°46'44.40" JOHN F KENNEDY INTL
Note how we start at N55 but as soon as the flight starts you are heading in a North Westerly direction such that a flight to New York from England UK actually flies over Scotland.
Hope this helps!!
Brian
Think we are a bit off topic .. but that's clear as mud to me (and some other non aviators..i'd imagine)  :D
Offline bumpkin
      Aberdeen
Take a ball and measure round the centre with a piece of string.
Move up the ball from the centre and you will need less string to measure round the circumference, simple as that.
The quickest round the world tour would be at the poles, you could simply walk round them and you have by definition circum-navigated the earth!!
Yeah I understand that but that is still assuming you are going in a straight line horizontally if not vertically.
The way I understood your explanation I imagined for example if you were going from say Sydney Australia to Perth Australia it would be quicker and shorter to say fly over Adelaide (roughly) instead of going directly as the crow flies (due to the curvature of the earth)
Offline bumpkin
      Aberdeen
That is correct Darryl, a flight from Sydney to Perth is routed just to the North of Adelaide and via Mount Hope.
Here is a pic showing the sine wave type route which would be used
Remember maps are flat, draw a straight line on it then curve it into the shape of the earth and you automatically get an arc.  Now this arc may just have become a longer distance than you need to fly so the plan is altered to reduce the distance if possible.  For the Atlantic crossings the routes are given a specific name, they are called NAT or North Atlantic Transitions.
It's about compromise, you can get the shortest distance but this may not be suitable due to flying over large water masses so you must compromise a route to keep you closer to land but still keeping the distance to a minimum.
Like they say.. you learn something every day  :razz: (Never too old to learn)
Offline Hemmi
    • is Iceland
      Reykjavik, Iceland
I sometimes see planes fly over, I wonder where they're going, Los Angeles? Canada? Asia?
Offline bumpkin
      Aberdeen
Most flights which you would see going over Iceland would be to or from the Americas and Canada from European destinations.
Asian flights from Europe go the other way and Asian flights from the Americas tend to be trans pacific.
Offline Hemmi
    • is Iceland
      Reykjavik, Iceland
I would like to fly over Iceland sometime, and Greenland, I flew once over Faroe Islands and Norway and it was nice, beautiful mountains and landscape, I assume the same about Scotland :wink:
Edit: I think it's time for Shambles to find his scissors and move this Flight topic to a new thread  :razz:
