The ABS has an electrical motor which self regulates hydraulic pressures in line with the ECU in the monitoring system, over time the pressures have to be re-established and the motor activates briefly. This is from the workshop manual and IMO most likely what you can hear, perfectly normal.
Hi Phil,Original oil as per Hyundai service dude is a 5w/30 of whatever is the cheapest on the day, today we used Veales 15w40 homebrand which is probably not a great deal better except for the viscosity...and the tappet chatter still seems to be there....slightly
Hi folks,Newbie on here and also an i30 owner that has a similar noise on occasion. Mine is a 2013 GD Active 1.8lt petrol, and is used as a driver instruction vehicle. It was purchased in April this year and I've racked up 16000kms already.Anyways...I have the same (or similar) sound every now and then and to me it sounded like a servo type thing....the ABS explanation makes sense however I've never heard an ABS system do that on any other car before. Talking to my best mate mechanic today during an oil change (to try and remedy some tappet chatter...I'll get to that shortly) it made the whirring noise on startup....asked his opinion (which I regard highly) and was told it was from a small clutch system in the alternator just picking up speed to match the drive belt...also makes perfect sense and have actually heard a similar sound from "clutch" cooling fans on Commodores/Falcons etc.Now to my other issue....tappet chatter.This is becoming a concern as being from a race background...when I hear a metallic noise from the engine I tend to get quite worried that something aint getting oiled properly. Now this noise isn't exceptioanlly loud but I do hear it...particularly at cold startup when it takes about 10mins to clear and then on and off during my day of driving around town....local dealer said....bet you'll never guess..."it's normal" but I beg to differ as it seems to be getting slightly more regular.As per others here it will be taken back to dealer for another listen and check and will let you all know the outcome.Shame....coz otherwise it's a bloody great little car!! Cheers!
Stinger, did your mechanic mate say why the small clutch picking up speed doesn't happen on every cold start ?
I finally got a response from the dealer. It is indeed the oil pump cover. I did tell the mechanic about this forum and how Purple's issue with his car got resolved. With Hyundai's assistance, the dealer was able to diagnose the problem. The part is now on order from Korea.
