I think the handbrake is the "shoe" type, operating within the wheel hub.
If they've been grabbing then the calipers almost certainly need overhauling, else you'll be up for another set of pads/rotors before long. Also, if you do decide to do them yourself, I'm pretty sure you need a special tool to wind the pistons back into the caliper so the new pads will fit. There has been some discussion on here about this.
Quote from: Surferdude on March 21, 2013, 11:34:34If they've been grabbing then the calipers almost certainly need overhauling, else you'll be up for another set of pads/rotors before long. Also, if you do decide to do them yourself, I'm pretty sure you need a special tool to wind the pistons back into the caliper so the new pads will fit. There has been some discussion on here about this.No special tool required. I changed the rear pads on mine last year, IIRC I just pressed the piston back.
Well, I went to an independent garage this afternoon and after inspection was told the brakes are fine. The front were only about 25% worn and the rears had at least another 25k still on them. I AM TOTALLY CONFUSED and reluctant to trust anybody now.I then phoned my Hyundai garage that carried out the service and spoke with the service manager who told me the same thing that it has been caused by brake dust and winter conditions. When I mentioned that the car had been serviced since new by them and nothing untoward was raised at the 2nd service a year ago, and ONLY 7750 miles later, they sat up a bit. Furthermore, I also told them I had been on various Hyundai websites [This in particular] and nobody had experienced the same problem at such a low mileage. The service manager then said the only thing they could/would do was to contact Hyundai Customer Services [Head Office] tomorrow and see if they could/would do anything as a goodwill gesture.I won't hold my breath but will let you know how I get on tomorrow.
Quote from: Asterix on March 21, 2013, 18:36:16Quote from: Surferdude on March 21, 2013, 11:34:34If they've been grabbing then the calipers almost certainly need overhauling, else you'll be up for another set of pads/rotors before long. Also, if you do decide to do them yourself, I'm pretty sure you need a special tool to wind the pistons back into the caliper so the new pads will fit. There has been some discussion on here about this.No special tool required. I changed the rear pads on mine last year, IIRC I just pressed the piston back.Thanks Asterisk. My memory must be playing tricks.
Quote from: Surferdude on March 21, 2013, 20:34:05Quote from: Asterix on March 21, 2013, 18:36:16Quote from: Surferdude on March 21, 2013, 11:34:34If they've been grabbing then the calipers almost certainly need overhauling, else you'll be up for another set of pads/rotors before long. Also, if you do decide to do them yourself, I'm pretty sure you need a special tool to wind the pistons back into the caliper so the new pads will fit. There has been some discussion on here about this.No special tool required. I changed the rear pads on mine last year, IIRC I just pressed the piston back.Thanks Asterisk. My memory must be playing tricks. Surferdude there is a special tool to do that job,I have one but also as asterix says,you don't really need one if your switched on,that's why I own one
...I read somewhere about an adapter for the special tool which is used on many cars...
Quote from: Surferdude on March 22, 2013, 04:27:47...I read somewhere about an adapter for the special tool which is used on many cars...Yephttps://www.i30ownersclub.com/forum/index.php?topic=8891.msg104594#msg104594
A few points in response to the above excellent posts.Brake dust CANNOT contribute to wear on the disc rotors. It also can't add to the wear on pads. Simply, because the brakes are out in the air stream, any brake dust immediately blows away. Old Drum brakes had this problem because the dust collected inside the drum and needed to be cleared out occasionally by removing the drum.The best (IMHO) gauge for whether or not pads need replacing in once the pad thickness is less than that of the backing plate. Below this level, heat dissipation can be seriously affected, resulting in overheating brakes. which will get progressively worse as the pad material gets thinner.All rotors carry a stamp which should show their minimum allowable thickness and this is measured using a micrometer or a good set of vernier calipers. Again, operating below this thickness contributes to unwanted heat buildup and probable brake fade, not to mention heat spots on the rotors which will cause a pulsating pedal.Also, I shouold reiterate, if there has been excessive wear, it is most likely due to calipers binding (not releasing properly after you take your foot off the brake). However, this is something which would be much more prevalent in the front brakes rather than the rears which don't do a lot of hard work.
I've done some brake replacements in the past so I'll tell you what I did.- Kmart in Oz used to sell a brake caliper tool which act like a reverse vice on the piston in the brake caliper, but they've reduced their auto section to the point of ridiculousness so don't bother trying to find one there.- It is best to use a tool like this, as it applies pressure evenly on the piston and minimises the chances of air getting into the system. The piston can only be returned into the caliper by slightly opening the bleed valve and you can expect some brake fluid to dribble out as the piston is wound into the caliper. The bleed valve needs to be closed while pressure is applied to the piston otherwise air can enter and that is bad, creates spongy brakes.- Note, the fluid level in the brake master cylinder naturally drops as the brake linings wear, always check this regularly.Regarding this particular car, I wonder why there hasn't been some evidence of trouble. I would expect the rotors to be heat affected, burnt steel colour (blue). After a decent drive, place a hand on each wheel and feel for excessive heat, should never be anything more than slightly warm.I can't understand why there is doubt about the remaining life of the pads. They have a new measurement of thickness and an old or replacement thickness, so your pads are either new or old, which is it.One of our cars is at 60k kms and no mention of any pad replacements yet, so yours are definitely abnormal, if the dealer is correct.
but the thread doesn't actually state you DO NEED a piston wind back tool it only shows you how too use one. Asterix has answered our question about needing one,or should i say NOT needing one.
Phil, I agree with most of your post.But, you don't need to open the airbleed screw to push/turn back the piston. I've never done that. But I will admit that it will propably make the job easier, but not opening it, saves you the mess with the brake fluid.
