but cruise control kept malfunctioning less it was me
I still find that an annoyance.
I think it actually checks the logic of the cruise control, not the brakes. It wants to ensure that the cruise control receives a brake signal so that it knows to disconnect.
Quote from: FatBoy on June 15, 2014, 08:21:00I think it actually checks the logic of the cruise control, not the brakes. It wants to ensure that the cruise control receives a brake signal so that it knows to disconnect.I just learned that cruise control is definitely not female (if it uses logic!)
Women use Fuzzy Logic.....
blame doggie...he starts everything.....even with the fuzzies on his face......
Quote from: patchpants on June 14, 2014, 17:39:03 but cruise control kept malfunctioning less it was me Cruise control won't engage unless you have touched the brake pedal atleast once since you started the car... could that explain your issue?
Austin A30 per chance?.....
Rick, where do you work? Are you with a car transport company?You can pm me if you prefer.
had an A30 for a short time
Rick, can't see your video. It says it's private.
