Hanook tyre pressure for i30 tourer
si618 · 13 · 6169
Offline si618
      Blackwood, Adelaide
We just got our new i30 back from it's first inspection. One thing I noticed was the service centre had inflated the tyres to around 37psi. Wondering why would they do that considering the recommended pressure is the standard 32psi? Is it better to run these K415 tyres higher?
I don't trust petrol station gauges much, although new ones seem ok if you overinflate a few psi and then lower to what you want, so use a digital guage I bought for my mountain bike.
cheers,
si
  • 2013 i30 GD CRDi Active Auto Tourer
G'day Si...
Many of our members run these sorts of pressures, in fact I run 38 psi all round.
Besides helping with fuel economy, the higher pressures sharpen up the handling a bit.
The ride might be a whisker harsher but the benefits outweigh that, in my opinion.  :goodjob:
Offline si618
      Blackwood, Adelaide
Ok, thanks, so long as it's not going to cause premature wear, happy to give 38 psi a shot and see how it goes.
I already like the handling in our car, it seems to perform well in the Adelaide hills, but I'm coming from a 22 year old Subaru liberty wagon, so not too hard to be impressed ;-)
Cheers Si.... :goodjob:
While I have no proof, I suspect running 32psi would actually result in premature wear, more so with the added weight of the diesel engine which as far as I know, Hyundai make no allowances for with their quoted tyre pressures.  :undecided:
Offline Just Rick
  • Big Dogs Rule
      Beverley Western Australia
  • miracles can happen
Si common practice to run higher than recommended pressures in any front wheel drive car,actually helps tyre wear,I actually run 40 psi in the fronts and 36-38 in the rear
Offline Hati
      Perth WA
I also run 40 up front and rear as well since I lug around a lot of work related stuff, probably 60 to 80 kilos all up.
Oh... By the way what is a Hanook??? :D
  • 2017 i30 Elite PD
Si,
Did you check when hot or cold?
If hot then psi would not be 32 due to heat generated in the tyre highers the psi
Offline Just Rick
  • Big Dogs Rule
Ignore Dave and his smart response,Hankook is a Brand of Tyre Hati,I'll be the helpful one  :whistler:
40 all around for Firty. :victory:
Sure it's not firty all round for Forty?  :undecided:
:snigger:
