replacing alternator belt
dibboi30 · 37 · 29806
0 Members and 14 Guests are viewing this topic.
Offline dibboi30
      Sunshine Coast
Hi I have a 2010 diesel i30 and have done 120,000 km, I am about to replace the drive belt I have read other posts on the subject the detail using a hex key.
All the pulleys on my engine are torx bits and posts didn't exactly show which pulley is the tensioner, could anyone throw some light on this for me.
                  cheers dibboi30
Well, you'll have to use some commonsense because the workshop manual is not a very good diagram.
All the pulleys in the accompanying diagram have a function except the small pulley under the letter A.
I think this is the tensioner, it is spring loaded.
drivebelt.pdf - Google Drive
« Last Edit: April 21, 2014, 12:53:46 by Phil №❶ »
Offline Just Rick
  • Big Dogs Rule
      Beverley Western Australia
  • miracles can happen
Phil that is not a pulley under the letter A in the second photo,that is in fact the mounting hole for the alternator mounting bolt,dibboi30 ,the tensioner is the very front pulley when your facing the motor,I for the life of me don't know how you are able to de tension it, unlike the commodore,falcon and nissan ones I have changed these belts on before,they have a hex head bolt which you are able to get a spanner on to apply pressure to de tension them,both my I30's on this pulley only have a phillips head screw in them,if you find out how to de tension the tensioner,could you pass on how you did it.
But getting on to changing the serpentine belt,funnily enough I was having this conversation with my mechanic on the weekend,as I was asking when it should be changed,along with the guide pulleys,his answer was if at each service there was no sign of cracks or missing ribbing pieces,do not touch it,only time to change them is when they are showing signs of wear by cracks or missing ribbing and change all the guide pulleys at the same time
Oh and forgot to say Hyundai service centres WILL NOT tell you how they change the belts,or get the tension of of the belt via the tensioner,they just say You will have to bring it into us.
Sounds like it will cost an arm and a leg to replace when it does need doing...  :undecided:
I did realize that Rick-p, I figured anyone looking at the diagram would follow the path of the belt. There is no belt at the spot you refer to.
Offline Just Rick
  • Big Dogs Rule
sorry didn't see the letter A in the first diagram until I put my glasses on,that little pulley is a fixed one,as said the front one is the tensioner(well is on both of mine)the picture in the manual does show them having hex head fasteners but like I said mine have phillips head screw type bolts in them,never looked at anyone else's cars
On a previous car with a similar belt drive path the alternator was mounted on a top pivot and a tensioner bolt under the alternator. You pivoted the alternator outwards from the engine to  tighten the belt and then lock it in place with the bolt in a crescent shaped slot.
On my Vega the alternator is pivoted from the bottom and there is a tensioner bolt above it.
Is the i30 alternator mounted in a similar way?
I'll have a look in the engine bay today.  :whistler:
Thanks, Rick / Alan.
Offline dibboi30
      Sunshine Coast
Thanks all,
I have since heard it is spring loaded I will try the front pulley ,mine  has a torx bit not a Phillips head I will get a set and give it ago.
Have done a bit on different cars over the years have not seen this type of tensioner before. The reason I want to replace it a mates i30
with 150,000 k the belt was in a bad state. I will let you know how the belt replacement goes.
                                 regards dibboi30
Offline adyadad
      Bundoora, Vic
I recently did my daughter's car and it's not the torx.   If I remember correctly, its the pulley second from the front, (directly below the A on the diagram).   Just near that pulley is a bolt head which is what you twist to remove and replace the belt.   At least on the 1.6 diesel it is.   I ended up removing the wheel and engine splash guard to get at it easier.   I've only done it once and can't remember which way to turn it.   Once the new belt is on, it's self tensioning.
The one I replaced had 100.000 km and was cracked as well as small holes all the way through.
cheers...Andrew
  • I30 CRDi
Offline dibboi30
      Sunshine Coast
adyadad ,you are correct I went out this afternoon looked at it for a while removed the wheel cover etc changed it no problem, the tensioner pulley
is the one located between the air con unit and the crankshaft pulley a little higher up using a 14 mm ring spanner on the alloy hex this moves it against the spring loading.
If you need to remove the pulleys torx bits are needed .
         thanks dibboi30 p.s. while doing the belt change I noticed air con oil leaking for a hose near the radiator off to Hyundai for warranty!!
Offline Just Rick
  • Big Dogs Rule
Thanks for that.sounds quite simple,I'll take a gekko at mine next week,I prefer to take them off to get the best inspection,you wouldn't happen to have the belt part number.
Offline Mike Lawson
      Nottingham
Hello There.
I have just changed the serpentine belt on my 09 I30 crdi.No need to remove anything you do it all from the top. A 1/2 drive 14mm socket and a 2 foot breaker bar,that's all you need A picture/drawing of the belt path can save a bit of time if you have a memory like mine!The Gates number of the belt is 5PK 1810,that's what fits mine.Easy job,by the time you have read this post you could have fitted 2.
                                                         Regards Mike
  • Hyundai I30
Thanks for that, Mike.....and welcome to our little forum...  :goodjob:  :drinks:
Offline adyadad
      Bundoora, Vic
Hello There.
                                                         Regards Mike
I didn't have a long breaker bar and it was a bit tight to get my hands in.   That's why I did it that way but your way sounds easier.   Good excuse to buy more tools.
There's 2 different belts.   Mine's the earlier one and is about 15 mm shorter than the later.   The changeover is about April 2008.
cheers....Andrew
  • I30 CRDi
Offline Mike Lawson
      Nottingham
Thanks for the Welcome lads
      adyadad.You are correct the early belts were shorter,they change the water pump and pulley not long after the I30 came out.When I mentioned the breaker bar thinking about it you could get away with a "T" bar or a ratchet. What  ever  you can lay your hands on.
                                                      Regards Mike
  • Hyundai I30
Administrator Comment Awesome example of co-operation guys .. Thanks to everyone for their input (what a great bunch of members we have)
AW gee Dazz, you're only saying that, 'coz it's true.  :happydance:
Offline John B
  • John B /aka Sloop
      Gold Coast Qld
Hi Mike , You snuck in here quietly with a good post, if you thought you would get away without a warm welcome, not going to happen , welcome welcome &  :welcum:
  • Toyota Kluger KXR AWD
Hi Mike ,  if you thought you would get away without a warm welcome,
Good point, I better put the kettle on!   :goodjob:
Offline John B
  • John B /aka Sloop
      Gold Coast Qld
White with two please. :goodjob2:
I'll have black with milk please.  :)
... and I'll have 5 sugars but don't stir it ('caus I don't like it too sweet!)  :winker:
Offline dibboi30
      Sunshine Coast
Hi Rick belt serpentine #25212-A310   $17.35 Lada & Korean Parts Australia  they are at Deception Bay Qld 07 32934994 have all the filters at reasonable prices.
Offline Just Rick
  • Big Dogs Rule
Hello There.
                                                         Regards Mike
Mike
I took to one of mine today and believe me you have made it sound overly simple(which it is to a degree)but with huge gorilla arms like mine,it is far easier to take the extra time and remove the drivers front wheel and the plastic side cover,as I found it very easy to get off the way you explained,but getting it back pn was not that simple,as over the guard I could not get my Gorilla hands nor my arms into the places they had to go to put the belt back on correctly.
Other thing that pissed me off while having it off and inspecting it,I did notice all the part numbers were still in tacked and guess hich dumbass forgot to write them down  :disapp:
Offline crazykev
For future ppl who find this thread, I did mine today, in 15mins with a 2 year old playing in the car.
If you are a bit resourceful its pretty easy just to do it from the top. The tensioner bolt is 14mm and just under the pulley. just give it a little pull and when you see the pulley deflect, you've got the right one. Its good to use 1/2 drive breaker bar with and extension handle to make to easier on your other arm when you are snapping the belt over the tensioner pulley. Make sure the belt aligns well on each pulley as your pulling it over the tensioner pulley. Also once the belt is on, it pays to get the torch out and have a good check of the alignement, and give it a couple of cycles with the key (no start) and go back and check that everythings tracking right.
It would be good idea to keep the old belt and stow it away under the spare in case you get a snap on a big trip. High chance of not needing it, but if you snap a belt it the middle of nowhere it would be a lifesaver.
I got my belt for $17 from that guy at Lada and korean parts at deception bay, what a legend. Air filters were, $8 oil filters $12, fuel filters were $18.70. The fitlers were all made in Korea and look to be pretty good. The belt was made china but they all probably are nowdays.
  • i30 FD diesel slx
You let your kids play in the car  :Shocked:
Good work, those are good prices on the filters . Welcome by the way, another Brisbane diesel member. If you had a wagon you would be perfect  :lol:
 :welcum: crazykev and thanks for the helpful 1st post.. :goodjob:
What was the reason for changing if you have put the old one in the boot as a spare?
