Are you sure it's not your eyesight that's failing, Alan?
Quote from: rustynutz on March 16, 2015, 13:03:41Are you sure it's not your eyesight that's failing, Alan? If it was - I wouldn't have noticed any difference.......
I like happy endings
Quote from: Dazzler on March 25, 2015, 22:11:34I like happy endings Provided there isn't a thumb in the way.........................
Was the camera calibrated correctly and did you alter any settings after taking the first reading?
Quote from: eye30 on March 25, 2015, 22:54:26Was the camera calibrated correctly and did you alter any settings after taking the first reading?Yes and No respectively. The comparisons are correctOn each occasion I took 3 readings and they were consistent. My garage has no windows and with the door closed it is like the black hole of whatsitsname. Hence there was no extraneous light to spoil comparative accuracy.
I just got back from a trip in the car during which I was sure the screen had dimmed again.When I got home I did another check and it is back to 80 lumens again.
Quote from: AlanHo on March 26, 2015, 10:05:33I just got back from a trip in the car during which I was sure the screen had dimmed again.When I got home I did another check and it is back to 80 lumens again.Is it diming as a battery saver mode?
Does the screen dim when your lights are on Are your lights on
Don't you hate intermittent problems, knowing full well that if I take it to the dealer it will not misbehave and I will politely get treated like the village idiot who sees ghosts.
Thats good Alan, I bet your pleased that is sorted .Nothing worse than those intermittent problems.
Quote from: John B on April 30, 2015, 05:13:31Thats good Alan, I bet your pleased that is sorted .Nothing worse than those intermittent problems. Hopefully you will get up to date maps too...
A second voice says "Shush - the camera's running". The technician says "I know that". They then have a chat in hushed tones with the radio on - I can't hear what they are saying until one of them says "We've wasted enough time - the bloody things definitely faulty"
