...My conclusion is that there is little to choose between them in terms of cabin noise on rough surfaces. The main differences seem to be related to the size and weight of the car - the smaller and lighter are the noisiest and the big and heavy more muted. I have wasted a lot of money in having cars fitted with sound deadening materials and changing tyres for precious little gain other than from the placebo effect.So my message to you is if you honestly believe the SEAT to be better than the i30 in terms of cabin noise - then go buy one. Most i30 owners here are happy with their choice of car and are able to put up with the terrible din you refer to.
I changed mine to supposedly quiet Continentals and it made no difference to my ears.
On my original hankooks the road noise varies depending on the road surface.I have noticed on so call new low noise surfaces the noise is alot lower than "normal" surfaces.So my conclusion is that it depends on the road covering to whether high or low noise and not the tyre.
.. if you read back on this thread I mentioned the tyre pressure warning on three tyres alerting on the dash - well when I talked over this with the Hyundai dealer his response was "we get a lot of complaints about that - but don't worry most of the time the tyre pressures are fine - it's just that the system is overly sensitive"...he said that this usually happens when the car has been parked in the sun and the temperature increase on the tyres causes the warning to go off..
So, is this an example of Hyundai dealerships?
No I didn't check the tyre pressures - what got my goat the most was the salesman reporting this as a common problem and brushing it aside as if it was of no concern - and of course that you can't conveniently reset the error condition like you can on VW, and that I parked it in the sun (at 7am on an Autumn day) which is what probably tripped the condition.So, is this an example of Hyundai dealerships?
Quote from: cdgeorge on October 01, 2015, 13:22:53So, is this an example of Hyundai dealerships?No, but Salesmen generally
No as I said, they replaced my TPMS stems which I really didn't expect FOC, given that the problem was self inflicted. I very much doubt that any other dealer would have given that result.As far as resetting a warning is concerned, surely you shouldn't be able to reset a warning unless you had rectified the cause? I think it is a pretty bad design to be able to push a button to make a safety warning go away, the whole point is it SHOULD be in your face until you get it fixed.
