0 Members and 21 Guests are viewing this topic.
Hi all,6.5 year old FD i30 6 speed manual i30 and problems are starting to creep in. Every issue I have had, I google and up crops someone else with the issue on this forum (clutch shudder, broken power window).I've noticed my clutch bite point is now starting only a few cm off the floor. Which means that I have to be super careful to push it all the way to the floor to change gears. If it's even a cm off from fully down you can run into resistance pushing it into gear.I see someone has commented that they had this problem and that it may have been a damper issue on the master cylinder. Low clutch bite point resolutionMy mechanic does not deal with a lot of Hyundai's. He's mentioned a few times he feels they aren't as reliable as Japanese. I suspect when I bring it to him in a few weeks he may just suggest a new master cylinder. I'll show him this thread.Anyone know what the price of these might be? I've searched ebay and they don't seem very common. Only second hand or aftermarket slave cylinders.
Thanks for that link, I may try that myself. The bite point is driving me nuts and very uncomfortable . My only real annoyance with it.
Quote from: tw2005 on March 02, 2018, 10:29:23Thanks for that link, I may try that myself. The bite point is driving me nuts and very uncomfortable . My only real annoyance with it.How many kms has your car done out of interest.
381000K, can't confirm history. has books with stamps but no detail. Only had it a short while but definitely country hwy with lots of dirt roads.
Quote from: tw2005 on March 02, 2018, 10:59:08381000K, can't confirm history. has books with stamps but no detail. Only had it a short while but definitely country hwy with lots of dirt roads. Well maybe that means I have another 280,000 km before my clutch really becomes a problem.
First thing to check would be the clutch fluid. Slaves can leak into the boot but not show unless you pull the boot back. Master maybe but very uncommon.My most likely scenario would be that at 30000km+ your clutch plate has possible just simply reached the end of its wear life.
If the original damper IS deemed to be at fault, it would make more sense to me to replace it with a new one (if it is available) rather than blanking it off with a sump plug.Does anyone know if Hyundai has the damper mentioned here available as a separate part?
Hyundai i30 2007 clutch problems. Fault finding and repair. - YouTube
It was a good video, top marks. He seems to have dealt with the problem.however a 300,000km setup may also have the worn parts he talks about at the end of the vid.tw, From my what I see in shed 2, the clutch is not self adjusting. If I get time I will pull a clutch off a flywheel and check that these are solid flywheels. That is why they have a damper.Most larger diesel motors have a dual mass flywheel that smooths out the inherent lumpiness when engaging the clutch.They are a spring loaded affair and usually fail within five years. The damper is a much better arrangement.If you eliminate the damper you will get the vibration, but so do a lot of 'real men' who change to a solid fly wheel.
If the damper is worn it won't really be doing an effective job at the moment. What are the potential implications of removing it?
Quote from: nzenigma on March 03, 2018, 03:40:28tw, From my what I see in shed 2, the clutch is not self adjusting. If I get time I will pull a clutch off a flywheel and check that these are solid flywheels. That is why they have a damper.even more confused now, where the heck is the adjustment then?
Quote from: tw2005 on March 03, 2018, 03:51:36Quote from: nzenigma on March 03, 2018, 03:40:28tw, From my what I see in shed 2, the clutch is not self adjusting. If I get time I will pull a clutch off a flywheel and check that these are solid flywheels. That is why they have a damper.even more confused now, where the heck is the adjustment then?Ah has bin an lookd massa!Its a solid flywheel and just the usual sort of clutch driven and pressure plate.The only truely adjustable clutch plate Ive come across was supposed to be on the BMW, but the replacement was just the common type.As the driven plate wears, the fingers of the pressure plate protrude more, and get closer to the thrust bearing. I guess thats adjustable. Quote from: constipated on March 03, 2018, 04:02:25If the damper is worn it won't really be doing an effective job at the moment. What are the potential implications of removing it?Not much. You will/may feel a bit of vibration in the clutch pedal especially when you are wearing high heels.
If it happens to just be a worn clutch plate and not a failing part in the hydraulics then something like the clutch pedal adjuster might help get a bit more life from it Clutch Pedal Adjuster - Shark Racing
I removed the damper yesterday but no change in pedal travel till engagement point. Is still pretty low.
