Backup OEM camera retrofit
Offline aanastasiou4
    • cy Cyprus
I retrofitted today the OEM hyundai badge camera. I only connected the open/close function since I am waiting for my GD-03 head-unit to arrive!
  • Hyundai i30 2012
So this will fit any GD model?
    • cy Cyprus
Yes! You have to remove the badge of a non camera fitted model and cut the hole for the camera assembly! You have to splice the wires and extend them to go all the way to the radio (gd-02, gd-03 radios only)
Red wire: connected to the battery
Black wire: negative
Green wire: connected to the backup bulb
Blue wire: (ignition) connected to the + of the cigarette plug.
The above wires are only for the open/close function. When I connect the camera I will explain that too!
« Last Edit: April 24, 2018, 20:54:59 by aanastasiou4 »
  • Hyundai i30 2012
@aanastasiou4
 :ta:
What steps did you take to avoid future corrosion issues on the cut edge and what did you use to cut an oval hole. Was it tricky?
    • cy Cyprus
I used touch up paint on the cut edges. To cut the hole I marked the area and used my drill to cut through!
  • Hyundai i30 2012
    • cy Cyprus
I connected the camera too and it works perfectly!
  • Hyundai i30 2012
Excellent! Well done!  :victory:
    • cy Cyprus
Inform me if anyone wants me to explain the procedure:)
  • Hyundai i30 2012
Offline smash046
    • ro Romania
      Transilvania
Congratulations for the great job!
For the opening / closing function you explained the cable connection!
Can you explain the camera connection as you promised?
  • 2015 GD 5 Door Hatch, Petrol 1.4, Manual, Blue
    • cy Cyprus
You have to extend the wires from the camera connector to run them from the tailgate all the way to the radio.
The camera wires are coloured so it is easy to install it.
Blue wire: camera power. Connect it on the reverse light. Also because I couldn’t got the signal wire on the radio to work I connected this blue wire in the signal pin hole (position a9 on the radio connector)
Red wire: video out (a15 pin hole on the radio)
Green wire: video ground (a14 pin hole on the radio)
Black wire: camera ground (a5 pin hole on the radio).
This diagram might help you.
  • Hyundai i30 2012
