Injector rail problem for engine replacement from 09/07 to a 2009 engine
munro7389 · 83 · 19848
Offline munro7389
      Queensland
All sorted. I had the 2 plugs around the wrong way. The grey and black ones on the solenoid lol. Silly me. Runs like a dream. Thanks
  • 09/2007 i30 diesel
 :goodjob2: Glad its sorted.
Awesome great result! Thanks heaps to our amazing tag team for all their comments and support.  :goodjob2: :goodjob:
About time.  :head_knock: glad you got there.  Lessons to be learnt.  I use my phone a lot these days to capture original configuration.  Especially on a project that may stretch over weeks.  :faint:
Offline munro7389
      Queensland
Until the clutch just started slipping...frustrating. I used that spacer plate for the gearbox and bell housing too if that makes a difference. Clutch is only 6 months old
this may help    :link: Injector rail problem for engine replacement from 09/07 to a 2009 engine
 :crazy2:
Offline munro7389
      Queensland
Will that make a difference on how the clutch operates?
yes in theory, pedal travel, cause slipping? probably not
The plate has nothing to do with it. Mine has the plate as yours would have too. Slipping is related to clamping pressure between the pressure plate, clutch disc and flywheel surface and condition of those parts..
If the clutch was 100% ok and now not, what has changed?
Can you describe the actions and what is happening. How is it slipping? DO you release and it just slips, you release and it slips then eventually grabs, do you release and it grabs but slips under high torque loads?
I'm likely not going to have a solution but some more information may provide clues?
Were the surfaces contaminated during remove and install?
Was it reassembled exactly how it was?
Is there any free play at the slave / releasing fully?
« Last Edit: August 25, 2018, 00:37:23 by tw2005 »
  :undecided: ??? on the manual or auto? I Have one on 2.0L auto but not on two diesel manuals. Not that it matters as you say.
Until the clutch just started slipping...frustrating. Clutch is only 6 months old
Its was ok then started to fail. Oil leaking onto plate. Forgot to tighten Pressure plate bolts.
April 2008 SX 5spd manual FD CRDi , same production version.
Are we safe in assuming the pressure plate bolts were torqued up?
Clutch slips
 Insufficient clutch pedal free play
 Adjust the pedal free play
Clogged of the hydraulic system
 Repair or replace parts
Clutch disc lining oily or worn out
 Inspect the clutch disc
Faulty pressure plate
 Replace the clutch cover
Clutch slipping
● Car will not respond to engine speed during acceleration
● Insufficient vehicle speed
● Lack of power during uphill driving
Insufficient pedal free play
 Adjust
Clogged hydraulic system
 Correct or replace parts
Excessive wear of clutch disc facing
 Replace
Hardened clutch disc facing, or oil on surface
 Replace
Damaged pressure plate or flywheel
 Replace
Weak or broken pressure spring
 Replace
« Last Edit: August 25, 2018, 00:23:21 by tw2005 »
Think I'm muddled , I',ve removed reference to pull type.
Offline munro7389
      Queensland
Don't think anything has changed. But only thing I can think of is it was an auto engine b4 hand. When I fixed the vacuum problem it was running sweet. So taking it for a test drive the clutch was fine at high revs. Taking off and changing gears is fine. Just when you are driving when you put your foot down you can feel it slipping as in revs high but not going anywhere.
Everything seems quiet tight nip.
Same engine used for auto and manual. That's why a flywheel fits where the torque converter was.
Its slipping under high gear load. Check that the clutch slave is fully backed off. Adjust to
add some freeplay if necessary.
Offline munro7389
      Queensland
How do I adjust it and where from?
A very good question. @nzenigma
To my knowledge only adjustment is the pedal height, I'm yet to find any other myself as I'd like to adjust my clutch due to partial release.
Pedal height would be first , last shorten the slave shaft. But as you know, we generally get complaints that these diesels do not have enough travel. My brief reply was assuming that the clutch remains partially disengaged due to some misadventure . Back the pedal right off. Then he has to check for a bit of free play at the bell housing. eg Has the fork been fitted correctly.
Forked if I know, could crack the bleeder too?
I'm bunkered in for the rest of the arvo,  :goodjob2: :goodjob:
account removal page
Enjoy  :cool:
I thought it was the Op's car that had the biscuit!  :snigger:
 :spitty:
