This is new and old side by side. New one is FAI. Other end of the chain is in level with each other and other end reveals how much old is longer. On half way the difference is approx 3mm. The distance in between pins of the chain is 6.0-6.5mm.So totally difference is almost on full chain element! It's not surprise tensioner went to the limit.
Just made leak test by using ethanol. All 8 valves which were easy to test leaks.
Also, good to read about the hill starts and it not producing enough oil pressure for the tensioner - it would make logical sense and something to avoid where possible
What would the useable life of the timing chain be in this case? I'd hope for at least 300'000km, of course there may be outliers in the results such at this one but with my i30 nearing 250k km I am rather worried Also, good to read about the hill starts and it not producing enough oil pressure for the tensioner - it would make logical sense and something to avoid where possible
Quote from: PhireSide on September 14, 2018, 06:32:58Also, good to read about the hill starts and it not producing enough oil pressure for the tensioner - it would make logical sense and something to avoid where possible The knowledge I have comes from ex- East Europeans, (colleagues for many years) who work on VW Skoda etc. With due respect to Henri, he seems to be ignoring the fact that his chain failed on a hill start. No earlier symptoms such as rattle, or why a relatively low Kms chain failed, has been explored.@PhireSide with regard to 300,000km chain life, it depends on the motor. In the past 300,000 miles or NEVER used to be reasonable.However, we used to have large , naturally aspirated, 6 or 8 cylinder engines, that went for ever, we are now getting similar power out of 4 cylinder, 2.2 litre engines with a turbo.. Gut feeling tells me that these smaller motors will not last as long as the big old brutes.I think
I've been using and seeing the era of mechanical analysis on engineering since 2000. My feeling is that earlier before accurate analysis (FEM / dynamic analysis) engines had to build strong. The designer didn't have tools for optimizing. Today we have tools for optimization but what values designer type to software for stress analysis and lifetime analysis is still mostly manual math and educated/experience based guess. In theory and ideal world I believe these chains, for instance, works 300000 km but the world is not ideal. The stress of the engine is not ideal. Manufacturing is not ideal. Materials are not ideal. The designer has guidelines to make it small and light. As light and cheap as possible.
In the case of your jumped chain, is this an isolated incident? This is the first report here of premature chain failure in a petrol i30. There may be others, but usually a common fault will be discussed.
Not familiar with exactly those marks, but looks correct. Assume crank mark is at TDC? Would be good to check by turning motor over by hand with plugs out and watch cam positions as piston travels top to bottom etc. If it seems correct you are correct too.
Yes need to nurse air out & water in until thermostat opens. Try idling with cap off, watch temp and water level.
