Been busy as hell too.......................I missed the the correction to the donor and original motor data. Ive been assuming Steve had just mistakenly reversed the vin # s. Reassemble the 2007 motor and swap it for a 2009-2012. Job done.
Quote from: nzenigma on December 25, 2019, 20:29:30 Been busy as hell too.......................I missed the the correction to the donor and original motor data. Ive been assuming Steve had just mistakenly reversed the vin # s. Reassemble the 2007 motor and swap it for a 2009-2012. Job done. @nzenigma You did'nt miss it, I struck through last night. So in a nutshell his car was in fact 2009 model march, and the donor was in fact 2007 july.
Quote from: tw2005 on December 25, 2019, 20:44:50Quote from: nzenigma on December 25, 2019, 20:29:30 Been busy as hell too.......................I missed the the correction to the donor and original motor data. Ive been assuming Steve had just mistakenly reversed the vin # s. Reassemble the 2007 motor and swap it for a 2009-2012. Job done. @nzenigma You did'nt miss it, I struck through last night. So in a nutshell his car was in fact 2009 model march, and the donor was in fact 2007 july. Now I feel better. Was u that sober lash nite?
Fuel line Are this connection correct?The more I go through it the more I question myself
I was going down the engine number route too. Will hold my breath until you find them. tw do you also have my suspicion that this is not the original 07 motor?Steve said the egr was different so he changed them. However, I asked computor who said no... they are the same.
Quote from: nzenigma on December 28, 2019, 01:21:31I was going down the engine number route too. Will hold my breath until you find them. tw do you also have my suspicion that this is not the original 07 motor?Steve said the egr was different so he changed them. However, I asked computor who said no... they are the same. No idea what's going on, I've never had the data from the catalogs not match up with the VINs. Nothing is right here at the moment, we now have a 2009 car with a pump 2 years younger and like wise with the early 2007, it has a pump made after it left the factory.
P0341
sorry mate, i just went back to double check everything. thats why i asked about the fuel line routing (since you can get the connection wrong). i connected my launch x431 diagnos tools. tested a few components. pump, sensor pump, check the injectors. everything was correct.fuel rails sensor i just swap over again with the other sensor i had. now i need to bleed the system again. sorry i didn't answer your question nzenigma. yes i did try to crank and see if there are fuel coming to the rails and there was. but i will check and see what pressure i get on my diagnos tools. i will take down the engine number tomorrow. sorry for all the late reply since we have a big time different. today i got a email from a tuner . he only said that 90bhp and 116bhp have different software. he could not help me. since I'm getting P0341 . i still think if there are possible both engine have different voltage signal, sensor are the same, but the reading have set different signal on the ECU? ECU its not my area, but it just make me curious what range difference both engine have.
Also INJ Fuse 15A, (no.10) eng fuse box , check it is good
Quote from: tw2005 on December 29, 2019, 01:18:49Also INJ Fuse 15A, (no.10) eng fuse box , check it is goodLooked at that and did same as you must have..Noooooooo.... not THE fuse
i believe the number was the head number i took. sorry wrong engine number .
