I have a 2011 diesel CW and it's blown 6 headlight globes in 12 months four of which have been replaced by the dealer. Going back for a complete autoelectical check up next week.Never seen globes blow like this.So far the dealer has said there is nothing wrong and it's probably just bad luck but it's gone on too long.
Many cars (including some other Hyundai's) turn the lights off, while the car is being started -> you turn your key to "on" - the lights come on, you are starting the car - they go off, you've started the car - they go on again.
They said it's because of the "el. current" that "hits" the bulbs while the car is getting started.
Quote from: accim on September 20, 2011, 09:33:29 They said it's because of the "el. current" that "hits" the bulbs while the car is getting started. Interesting that you say the lights stay on when starting.If my radio/cd player and heater are on, ignition off, when I turn the key to start the car the radio/cd player and heater turn off. They then comes back on once the car has started.I'll have to check but I'm sure my lights go off as well.
Quote from: eye30 on September 20, 2011, 14:44:10Quote from: accim on September 20, 2011, 09:33:29 They said it's because of the "el. current" that "hits" the bulbs while the car is getting started. Interesting that you say the lights stay on when starting.If my radio/cd player and heater are on, ignition off, when I turn the key to start the car the radio/cd player and heater turn off. They then comes back on once the car has started.I'll have to check but I'm sure my lights go off as well.OK I've been out in the dark.Engine running.Turned all lights on Turned engine off and took key outOpened and closed door Put key in, lights came onstarted engine and the lights stayed ON (just as accim said)
Interesting. I'll check that myself.Fortunately i don't do a lot of stop Start driving at night anyway. Tend to drive somewhere and park for the night. But I also think I still manually turn my lights off when I stop. Old habits die hard.
Quote from: surferdude on September 20, 2011, 21:44:48Interesting. I'll check that myself.Fortunately i don't do a lot of stop Start driving at night anyway. Tend to drive somewhere and park for the night. But I also think I still manually turn my lights off when I stop. Old habits die hard.Hi Trev,It doesn't seem to be such an issue with the Petrol versions .. It is the diesel that seems to have the voltage surges (particularly when starting the car) I found in our previous diesel that the stock globes although not bright enough seemed to cope ok with the apparent surge but the Higher performance ones didn't
Fingers crossed that the issue is now resolved.
constipatedBy earth wire, they mean the -ve wire of the battery which usually is grounded th the car chassis.Elle bImported cars drive in OZ with HID fitted, so they're not illegal. What is illegal is the temperature that they glow at. I think anything over 6000k is considered illegal, they tend to glow blue / purple. I want to put some 6000's on my (wife's) car soon. Maybe our resident rule book looker upper can clarify this for us
Thanks Rusty .. Never simple is it
