i30 FD 2011 Diesel - Transmission leaking after seal replacement
Romen · 5 · 8875
Offline Romen
      Ashford, South Australia
Hi all,
Recently had the torque convert (TC) seal replaced due to a progressive transmission oil leak that got really bad. It was fine for about a week, then slowly started leaking again. Any suggestions on what might be the cause?
Reading the forums I noticed a couple of people reported micro cracking in the TC housing, which required replacing the TC. How common is that for these cars? Would it be easier just to place the whole gearbox with a second hand one in case the input shaft is damaging the seal?
The car has done 255,000 km and for the longest while was running rough until the head gasket was fixed. The massive trans oil leak from the bell housing and COVID price inflation warranted an engine swap and getting the seal replaced. Engine is great now but the oil leak is not fixed.. :(
Furthermore, do you HAVE to remove the subframe when removing the gearbox from the FD diesel? or can it be done with it in place?
Thanks everyone. :)
« Last Edit: September 26, 2021, 10:13:46 by Romen »
  • i30cw 2011 CRDi
Offline sundiz
      Helsinki
Factory manual says you need to take subframe off, but someone who has actually removed gearbox could tell the truth. There are many things mentioned In the manual which are not necessary in different jobs...
  • i30 cw 1.6crdi -08
Offline Romen
Just an update. You do have to take the subframe out. We ended up taking it to an autotrans specialist. I'll report back with what they find.
  • i30cw 2011 CRDi
Offline Romen
Looks like it was the torque converter was cracked around where the seal goes. :)
  • i30cw 2011 CRDi
Result! Thanks for updating :goodjob:
