HELP --- Car won't start
eye30 · 47 · 18301
Online eye30
Today the car won't start.
The engine turns over but will not fire.
(Same thing happened yesterday when I was out but started at the second try)
I let the Glow plug light go out as I do every time.
The temp is +8C so it's not a cold weather issue.
Battery seems OK as turning engine over.
Now I've read that if 1 glow plug is not working then it won't start so I'm going to check these first.
Fuel --- have half a tank and yes I did put diesel in and not unleaded.
Used my usual petrol station and the receipt says diesel.  Just checked it!!!!
Any ideas before I ring the RAC to come out.
(Rather not trouble them if it is something I can sortout easy as I'll loose my callout fee discount when I renew).
Could be the immobiliser playing up Lester try locking the car and then unlocking it again (or try your other key if you have it with you..) Good luck..
does the crdi have an electric fuel pump,or a mechanical pump?  :idea:
Online eye30
Ok finally got it started.
Checked fuel in tank (Although  I only topped up yesterday), fuel pump making noise when key turned, all wires connected, No loose Glow Plugs in holder, fuses for pump and other odds and sods OK ---- still no joy.
Just about to call the RAC and decided to give Daz's idea of another key.
Put the spare key in the ignition and hey presto kicked first turn.
Put old key in and no life.
Looks as if the key is at fault.
I'll change the battery as it will be the original --  Over 3 years old --- so may effect the transponder signal/immobiliser.
I'll see how it goes over the next few days as not back to work until Tuesday.
I'll call the garage next week just to see what they say.
 :goodjob: :brilliant:
Glad you got it sorted :D
I've been alternating between main fob and spare fob. Might be time to change both batteries here too  :goodjob:
Something to bear in mind too is, If you stick your key fob in your pocket, just be aware that when bending etc you may be accidentally pushing the buttons in.
I found this out when I was pottering around out in the shed and noticed the lights flashing on my i30 and heard the doors locking & unlocking numerous times....
It finally dawned on me what was causing it. Who knows how much this happens when I'm far enough away for the lights not to flash.  :-\
it will re lock automatically after 30 seconds anyway Russ.  :idea: :goodjob:
Yep, but I was more concerned that I'm possibly draining the battery in the fob when I'm away from the car by having the keys in my pocket...
Thanks anyhow... :goodjob:
:razz:
Online eye30
Decided to do some detective work on why the car won't start.
Now here is the result:
I have key fobs.
When I turn the ignition on with the spare key an image of a car with a key in it lights up --  Immobiliser indicator -- and the car started.
Now with the key I use all the time this does not appear and hence the car won't start.
Put new battery in the usual key fob and still it does not start the key
So my prognosis (my new word of 2011  :lol:) is the usual key fob is knackered!!!
I'll be phoning the garage on Tuesday requesting a replacement key fob under warranty.
Sounds like it needs pairing back to the ECU, if that's the right word
I'm pretty sure the immobiliser transponder chip in the keyfob is passive and doesn't rely on the battery in the fob.
great troubleshooting skills eye30.  :goodjob:
Online eye30
I knew it had to be something simple!!!!!!!!
Daz gave me an head start by mentioning the the other key once I'd ruled out fuel, fuse and ignition  (cheers Daz).
Car was running Ok last time I was in it so as it had to be an "overnight" issue and the temp is +8C , so wasn't cold related.
Also, didn't want to call out the RAC brakedown service if I didn't need too as they penalise you at renewal if you call out.
That's true.
Otherwise there'd be stranded motorists everywhere everytime the battery went flat.
Off topic I know but i had an issue with my Impreza when I went to drive off one day and - no drive. :faint:
Our driveway is slightly sloping so i tend to start the car and roll back onto the road in neutral then select 1st and drive off.
So this day I'm stuck in the middle of the road ( a quiet one, fortunately). I pushed the car into the curb (quietly, it was 5am and I was heading off for a surf). And went back to bed, figuring I had a clutch problem.
Lying in bed half an hour later I remembered I'd cleaned the inside of the car the afternoon before. With a dawning suspicion I went back out and found the "High- Low Range selector midway between the two settings. :rolleyes: :twisted: :-[
Good result Lester .. Glad my suggestion helped  :D
When we were in Perth WA same thing happened with the Son-in-laws car (a Nissan Pulsar)
Online eye30
Update.
Calling into the dealers on Friday to have the remote reprogrammed.
Need to take all keys to make sure they are all programmed the same
Seems the remote have 2 chips:
1 for the lock/alarm
 and
1 for the immobiliser - that is why the remote still locks the car!
Ask them how it could have become deprogrammed; that'd be interesting to hear ;)
Online eye30
I did but he had no answer.
Mentioned about 2 chips so may be 1 of the chips is US.
I'll ask again once it has been sorted.
I also asked what would the RAC have done if they had been called.
Sort answer - attach gizmo and then as it would have indicated electrical issue they would have advised/tow to dealer.
Whether they would have asked/tried the spare key -- who knows!!!
I only tried the spare because Daz mentioned it and I had nothing to loose as the car was dead anyway.
The immobiliser chip is a "SMARTRA" chip. As we suspected It doesn't get powered by the battery, instead when the ignition is turned on it gets power by induction from a coil in the steering column.
When powered up it receives  a message from, and then replies to, the control unit (or not in this case)
If the right response (an encrypted random number) is not received by the control unit the PCM/ECM light should blink and the fuel system is not enabled.
Hiscan(pro) is required to reprogram the keys with a new code and ALL keys must be done at the same time so they are all in sync.
The communication between the kep chip and controller is done at 125Khz.
The controller can work with up to 8 keys.
I would think the possibility of localized inteference on 125Khz (do you own any other RFID keycards?) or chip failure (as you suspect) would be the most probable causes, so let's keep our fingers crossed for the re-programme.
Does it still not work now, have you tried again?
Thanks for the techical info Lorian.. Complex technology just for a key  :faint:
Online eye30
Yes, try each time I get into the car and it still does not work
Online eye30
 Whatever these are the answer is no
Door keycards! I get to carry a couple all the time.
I'm guessing the chip is[/] dead then. If I undestand the diagram correctly the chip just gets inserted into the key housing and is not connected to the remote curcuit board at all, so if the have found it has failed it might be possible to just swap the ID chip and reprogramme.
is it similar to the Sim card in a mobile phone to swap over? :idea:
I dont actually have my keys here to look at, but the diagram seems to show it sat in a pocket in the key. I'm presuming when the key is opened you would see a little pocket in the plastic with this chip sat in it on its own, it's not very big, maybe 5mm long or so.
 :goodjob:
Online eye30
Update:
Took the car to dealers for the key to be reprogrammed.
Need to order a new key as the Chip is faulty.
Update:
Who needs dealers when we have Lorian  :goodjob:
