DRIVE-BELT
Offline mitchell
 I have a 09 diesel wagon its done 95thou Ks although it doesn't mention anything about replacing the drive-belt in the owners hand book I thought I would have a look and see whats involved but I couldn't see where any of the units the belt drives (power steering.air-con,alternator idle pulley)has any adjustment to allow enough slack to enable a replacement belt to go on.Any one done one.Cheers mitchell
Doesn't look too hard
There is hidden content here which only members can see. Please Login or Register.
Just follow instruction 2
The tensioner is the small pulley in the centre, it should be spring loaded, so the hex wrench needs to work against the spring tension, NOT ACTUALLY UNDO THE NUT !
WATCH OUT FOR YOUR FINGERS, TOO.
« Last Edit: March 10, 2014, 09:52:01 by Phil №❶ »
Phil
Cannot open link to Google Drive - I get Access Denied.
Try Now  :-[
Offline Just Rick
  • Big Dogs Rule
      Beverley Western Australia
  • miracles can happen
It is recommend to do the serpentine belt at the 105 thou k service,along with all three pulley's can get a set off of Ebay for around $160,I have gotten an individual price for the belt alone and that was quoted at $77
Offline Just Rick
  • Big Dogs Rule
Link won't work for me either keeps asking me to sign in.
Tried again and it's still working perfectly here... :)
Rick, try sticking your tongue out to the left.....  :p
Try this link instead
Offline Just Rick
  • Big Dogs Rule
Doesn't actually show you WHICH ONE is the tensioner,mind you I am guessing it is the front one looking at that picture
Well, ypu have Alternator, Water Pump, Crankshaft, A/C and 1 little one in the middle not connected to anything specific.  :whistler:
That's all the help you get, from the manual.
Don't know why the link is patchy :Pout:
Offline sfrtuscani
      Lynwood, WA
Does Repco sells the complete set of belts? Need to provide them the sizes or they have it in their database? Do I need to replace the idler and tension pulleys?
« Last Edit: February 08, 2015, 04:45:29 by sfrtuscani »
  • 2010 cw , Diesel 1.6lt, Auto, white
