0 Members and 15 Guests are viewing this topic.
Quote from: 2i30s on November 11, 2010, 09:26:08Quote from: agentr31 on November 10, 2010, 11:55:24genuine hyundai oil is shell oil... and the genuine branded one is like $80something i bought it once, ill never buy it again.... nissan genuine oil on the other hand.... ill get that anyday! my dealer uses castrol magnatech,they all use a different oil brand. we took both cars in for their 21.500km service thismorning and was informed they don't use the 5/w30 castrol oil anymore,now its shell 10/w40 because its a better oil for the i30 petrol engine.
Quote from: 2i30s on November 27, 2010, 10:04:47Quote from: 2i30s on November 11, 2010, 09:26:08Quote from: agentr31 on November 10, 2010, 11:55:24genuine hyundai oil is shell oil... and the genuine branded one is like $80something i bought it once, ill never buy it again.... nissan genuine oil on the other hand.... ill get that anyday! my dealer uses castrol magnatech,they all use a different oil brand. we took both cars in for their 21.500km service thismorning and was informed they don't use the 5/w30 castrol oil anymore,now its shell 10/w40 because its a better oil for the i30 petrol engine. and probably better for their pockets too
Bad news....I contacted Harold from performancelub the other day about when he was likely to be getting more German Castrol 0w30 and he told me that Castrol Syntec has been phased out by Castrol USA. It's no longer available......What a bugger....
Look up reviews for Castrol EDGE on BITOG website;It constantly shows 'almost no addatives' but always shows FANTASTIC UOA's.Meaning they're doing SOMETHING very very right!It'd be my next choice; and cheap too!
0-40W is, indeed, the better formula, however 40 Sheer weight is not needed. and in Australia, 0W can be too thin in the summer.
Very true.Problem was that I was trying to 'skim' the topic without typing ALL that out, lol. Thank you for doing it I agree it's easy to oversimplify.Cold flow weight matters because of 'clearance' how much space there is between parts to let oil lubricate; If n oil is TOO thin when cold, It'll ALL run back to the bottom of the sump and you really will be 'starting dry' *shudder*I'm not sure this is correct: An oil film without oil flow will be of very limited advantage. As soon as pressure is applied to the lubrication site the oil will be "squeezed" out. Oil flow is required to continuously replenish the oil. Therefore oil flow is the dominant requirement at starting (and at all times) which again is dependant on its viscosity.If an oil is too thin, even at cold, (which, outside industrial equipment, i know is almost a non-case) then it'll be 'pushed out' of the clearance or fail to be pumped correctly.An motor oil too thin at operating temperature will have been chosen poorly. An oil cannot be too thin when cold.Between 0W and 5W, who cares, you're totally right. and a 0W will always be 'Synthetic' yes, this however doesnt mean its 'good synthetic'. It can still be Base3 Hydrocracked synthetic (so chemically modified dino oil), and in a turbo application (say, the diesels) the 'hot weight' (or, shear point) is quite important. Agree, that the absolute difference between 0w and 5w is minimal. However as I said, to achieve 0w an oil will in most cases be a (better) quality oil and will almost certainly use base 4/5 in large quantities. The well respected Mobil 0w40 does, I understand, have some group 3 oil but it's unlikely a 0w oil can be made completely with group 3. Group 3 oils are second best oils, even though in practice they are perfectly adequate.I'd assume anyone who has done significant power increasing work on their car to be running 0-40 (for the higher film strength), and everyone else to be 5-30 (for warranty).This might be a case of over simplification.Because I'll be diesel chipping, and quite a few other little things, which I'll be keeping a build log for when i do, I'll be doing a 50\50mix, (same company and same range, so good chance its the same addative formula), adding a small ammount of Zinc and Phospherous, and an increase of Moly.If Castrol EDGE Sport is good enough for the Bugatti Veyron, its good enough for me.I admire your desire to get the oil right and I'm sure you will.
Well, now I'm totally confused...... :-\Went into my local Autobarn today to see if they sold Castrol Edge 0W40 (they did), ended up talking to the store owner (& his son) who proceeded to rubbish Castrol and recommended Nulon 5W30.His son actually has an i30 crdi and this is the oil he uses and he swears by it. His ol' man said that his son could use any oil he liked as he got it for free, but this is the one he chooses because, in their opinion, it's the best......He also told me some yarn about Castrol & Valvoline taking Nulon to Court over Nulon's advertising of their "AAT" additive and their claims of less friction than other oils. Anyhow, the story goes that Nulon won and Castrol & Co had to pay costs..blah blah blah. After being told all this, I decided to see if anything came up by doing a Google search.....Nothing! So, has anyone else heard of this Court Case or is it a whole lot of baloney? Oh, on the bright side, while doing a search I came upon this video.....
Things as thin as baby oil will show power gain due to less resistance on the moving parts, but its only so long before that oil breaks down, parts seize and you need a rebuild.
.. I personally want longevity from my engine 300,000 miles plus...
WRT Nulon: I'm not prepared to risk it even though it might be very good for all I know. The one listed above is not B4 (so is not correct for CRDi) but is B5. B5 does not supercede B4. B4 relates to High Temperature/High Shear (HT/HS) and is a measure of how the oil holds its grade (i.e., does not shear) at high temperature. This I suspect is particularly critical for the turbo bearings which will get very hot causing a localised superheating of the oil.
B Category (passenger car diesel engines)The B category is similarly divided with the exception that the B4 classification for direct injection passenger diesel engines has been established and that the B5 classification combines the performance requirements of B3 and B4 in a lower viscosity fuel efficient oil.
Quote from: Pip on January 05, 2011, 11:20:25WRT Nulon: I'm not prepared to risk it even though it might be very good for all I know. The one listed above is not B4 (so is not correct for CRDi) but is B5. B5 does not supercede B4. B4 relates to High Temperature/High Shear (HT/HS) and is a measure of how the oil holds its grade (i.e., does not shear) at high temperature. This I suspect is particularly critical for the turbo bearings which will get very hot causing a localised superheating of the oil.Interesting that you should say this, Pip as I was just reading Valvoline's "The Essential Guide To Motor Oil" and they had this to say: QuoteB Category (passenger car diesel engines)The B category is similarly divided with the exception that the B4 classification for direct injection passenger diesel engines has been established and that the B5 classification combines the performance requirements of B3 and B4 in a lower viscosity fuel efficient oil.
